Old December 29th 2011, 11:38
Wile the front is removeable, I have good access to drill the cage holes.
Never thought the hole would have this shape.
The cage can not hit the pedalbox, innerwing and fueltank, and has to end in the sparewheel well to be welded to the Porsche frontwheel mounts.
The cage will also run under the dash, this will fit perfect later on.
With this piece of cardboard the hole on the right will be easier.
Paul.
Old January 6th 2012, 17:31
Took the doors from the attic and dismantled them (they weigh a ton with all the windows etc.).
trail fitted the left door, fixated it with the wright gabs and made the first welds
When the right door is fixated and the pillar is tackwelded as well, I will start on the window surrounding.
Paul.
Old January 11th 2012, 16:44
And the right is getting there as well. Its not easy fitting a door in a shell that is not welded and bin appart completely
Paul.
