Dash pictures
Ok sorry for the delay have been very busy. Here are some pictures of my dash, i have added a little carbon fibre plate around guages on my one, they fit supurb! I just drilled a hole and screwed mine driectly to the original mounts between door and side of dash. The steering column also gives it support. Obviously it is a bare dash, you can fit what ever guages you like where ever you like. I have cut and mounted the original switches too, had to make some little and as many as you like. I also fitted my original switches in place has to cut small holes and fabricate small brackets to hold these. To be honest i would rather sell the whole mould to be frank, once an article has gone then the rest is history and as others know replicas are garanteed. I spent hrs and hrs fabricating this one off to replicate a 911 as close as possible, I have not seen another as good. Let me know your thoughts on this? Regards Brent
Can someone help? i simply cant attached the pictures? have tried 10 times. |
I've had the same trouble, loading them on a photo bucket account for now is about the only solution. Steve
Hello Brent this may help a little.
Download the pics to Photobucket, then when it comes to posting them you can hover over the pic you want and it will come up with different options, if you click the IMG code it will copy it and then just go on here and push past
I haven't seen another as good. Wait! I haven't seen this one yet...
dash info
Hi, i forgot about this thread, if you look in german tuning i have a thread in there..
http://www.germanlook.net/forums/showthread.php?t=11647 |
