Old February 19th 2012, 00:46
Bugged Bugged is offline
OK now some progress
The chassis is at the powdercoaters, and I should get it back late this week. In the meantime I have been taking apart the body even more. I stripped out the wiring harness as I'm going to be replacing it anyway. Too many random wires going who knows where.
Still contemplating how I am going to seal this off. May grind a bit off and weld/JBweld a circular ring to fit a boot of some sort.
Made this nice little bracket to seal up the holes I cut to move the bowden tube and accelerator tube.
I noticed this crack under the gas tank, I am pretty sure it is just the old sealant that is cracked... I don't think it is structurally compromised. What do you think?
Making car noises.
I made a cart to roll the body around on while im getting it ready to put back on the chassis. I can adjust the height with pins.
