Old May 17th 2012, 17:42
rennsport rennsport is offline
after 2 years like that, I decide to make some modifications.....
it ll be for another time, it s time to sleep for me
Old May 18th 2012, 17:08
ok lets go
january 2011
It was time to upgrade the brakes and the body...
4 944 turbo calipers, 4 Sebro sport discs, 4 red Koni, big front and rear sway bars
Old May 19th 2012, 03:15
after this , there was a problem....my Fuch touch the caliper, need spacer but at the rear haven t place to do that... so I decide to change the wheels ( the 3 rd)
but the color is not for good for me ( the silver one are with an 35mm offset this one 45mm)
It s BBS LM replica , other probleme they are in 5 x112 not 5 x 130 so I made adapters ...
after scouring
polishing
http://www.youtube.com/watch?v=9pPLDdZZXqo
and painting
with caps and stickers
fitting
at work
Old May 19th 2012, 09:07
After this major upgrade, I ll tryinf to collect parts for the mecanical upgrade..
EJ25 and Porsche 915 gearbox
the oil sump from Martin Bott
Porsche gearbox plate
throttle body reverser from RJES
throttle cable
fuel filter
Bosch fuel pump
speed sensor from RJES
Cosworth oil control baffle
the engine from a Legacy ( EJ25)
http://www.youtube.com/watch?v=2xl7MBe9RPw
Porsche 915/12 gearbox and shifter
plate from DS Tuning
wiring harness
VDO gauges sensor
header tank
water gauge
oil gauge
Vw rabbit GTI rads
master cylinder for the hydraulic handbrake
line lock
Mocal plates
Old May 19th 2012, 09:09
hydro handbrake
MC fit
LINE LOC
Sub parts
Porsche parts
ring of towing before painting
Porsche flywheel ring gear
Porsche clutch and Sub belt
the new plate
detailling
Old May 19th 2012, 09:22
new leather seat
try to see ...
at work ..
no many place for a girl
Old May 19th 2012, 09:29
june 2011
preparing the engine, bad news for the gearbox, some parts broken into it, need to buy another one cause it was to expensive to repare it, I ve found a 915/62 more longer and alu case...
mod on the baffle
cutting the oil sucker
I bought a Wevo shifter
Old May 20th 2012, 08:07
JULY 2011
engine out
Welded supports
fitting the gearbox
engine in place
I fit the seats and connect the driver one
engine and gearbox
replace H4 bulb by HID bi xenon
rads in place
dashboard mod
problems on the exhaust...
fuel tank mods
T3 parts
small panneling for the ecu and the sub wiring harness
water gauge sensor
the exhaust after cutting and correct rewelding
in place
too low , so cutting and welding
another in place
good
:mrgreen:
panneling
the gauges in place
Old May 20th 2012, 11:56
1st test
http://youtu.be/NaedQNkpuLw
before changing exhaust
http://www.youtube.com/watch?v=t9swDy8eIVA
detailling
nouvelle grille de boite sur le cendrier
dangerous mushroom !
