Old May 24th 2012, 14:55
-Alex- -Alex- is offline
Yeah, long strokes are more prone to flexing especially at high rpm use, maybe lighter pistons and rods help a bit. Thats way i decided to use all T4 mains scat billet crank. Probably limiting the rpm to 7000-7300.
Old May 24th 2012, 14:59
So what stroke are you considering that requires a .10" cam drop?
Old May 24th 2012, 15:29
Nah, 86 or 88 stroke doesnt require cam drop.
Got yesterday energysuspension sway bar bushings for weldable brackets to use with kerscher swaybar. A lot harder polyurethane than kerscher ones, and fits everyway better to my brackets than kerscher ones ( Obiwan is getting the same set also )
I also have now drill jig for safety wiring, easy to drill holes to bolts Recommended with wilwood rotors and hats with threads.
