Old December 17th 2012, 16:22
Originally Posted by NO_H2O View Post
Very nice work. Things are really cooking now.
Thanks. After a lot of hours repairing invisible pieces, it is finally time to make some bigger steps.
Old December 19th 2012, 17:12
there's a hole in the innerwing ;D. I am going for 6-7deg.caster, -1camber and 0 toe in/out.
Inside of the innerwing, not much space there.
And ofcourse I needed to test a wheel.
Paul.
Old December 22nd 2012, 16:19
Unfortunately I had to little space to move the spindle up n down. after some internet searching, I found out that the golf1 inserts will fit the Porsche strut and is 2" shorter. so I bought a used set to test fit.
if it fits I can shorten the complete strut by 2".
Paul.
Old December 28th 2012, 09:04
Point of no return (again)
I had planned to use more of the Porsche innerwing, but I did not have enough space. Now I only used the upper shockmount and made it 5cm higher. When I find the correct position I will weld it in the innerwing.
Paul.
Old February 20th 2013, 16:27
Finally did some work on VWrankenstein again.
Started working on the upper Shock mounts
Took out the rubber, shortend the the Porsche mount and made a plate to close the underside of the Porsche mount.
Test fit the bearing Busch
Underplate fits like a glove.
After some welding and grinding, I fitted the bearing. Looks pretty original. This bearing fits the Golf1 shocks perfectly
Bottomview
Paul.
Old February 22nd 2013, 16:42
Today again found some time for VWrankenstein.
To make sure there was enough space for wheel movement I bought Golf1 shocks. The Golf1 shock are about 5,5cm shorter.
Here's the difference.
Now the struts had to be shortend too.
And again some trail fit. (I used the wrong (too big) wheels)
Paul.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
