Old March 18th 2013, 22:59
cookvw's Avatar
cookvw cookvw is offline
liking the build. keep up the good work.
Old March 19th 2013, 07:21
Looking good. Love the shifter ;-)
Old March 19th 2013, 12:17
Exhaust tucks up nice and high, a good move.
Old March 24th 2013, 01:29
Purdy!!!
Old April 1st 2013, 18:48
Bogara_ZO's Avatar
Obviously
I managed to find a set of 25.5mm torsion bars from a 944 M030, I hope they will be fine with the "heavy" type4 in the back.
Berg-style mid mount:
Would be better to put in front, but the previous owner used a similar mount, thus he has already changed the bolts to longer ones, but this way :-/ So I need the rubber mounts to be releasable otherwise tranny can't be taken out.
Old April 1st 2013, 18:55
Bogara_ZO's Avatar
Installed the cup brace as well. 3 braces weight 1 kg together, while the 6 little ears weight nearly 2 kgs! Due to weight reduction and aestetichs the ears were cut a bit.
Fits nice with the Rancho:
Old April 1st 2013, 19:01
Bogara_ZO's Avatar
However the Rancho unit is already machined to accept a bigger flywheel, the 228mm is still too big, so we had no choice...it is still not OK, when all the screws are tightened the engine won't turn around next time I'll figure it out.
Friends are welding and grinding
Coffee break
Result of the day
Old April 6th 2013, 12:42
Bogara_ZO's Avatar
Has any of you ever changed the pilot bearing in the type4 crankshaft to accept better the input shaft of the type1 tranny? It seems just too short for me..thanks
Old April 6th 2013, 19:03
cookvw's Avatar
i just left mine in the crank. i drilled out my flywheel to accept a new pilot bearing.
Old April 7th 2013, 16:07
Bogara_ZO's Avatar
Do you have pictures of this?
Old April 8th 2013, 04:59
cookvw's Avatar
heres my build thread on stf when i orginally put my wbx in my other super. if you look closely in the pics you can see the brass bushing in the 200mm flywheel im using now. same flywheel as a type4 converted into a type1 tranny.
http://www.shoptalkforums.com/viewto...38817&start=30
Old April 8th 2013, 06:00
Just buy a new pilot bearing from any air cooled VW, there all the same size and have the flywheel centre turned to accept it.
Old June 10th 2013, 09:26
Bogara_ZO's Avatar
Thanks for the info guys! Will do it ASAP.
An other how to question, this time about the front oil cooler. Tubes will go under the chassis, but still not sure about the front area. I want to put them as high as possible without interfering with the suspension parts. Any ideas are welcome (picture worth more than thousand words). Thanks
Old June 14th 2013, 08:20
Bogara_ZO's Avatar
Originally Posted by Bogara_ZO View Post
They are in acceptable condition, so will give a try as is and see if I like them with all black carpets around or not. Retrimming is always an option.
I wasn't happy enough, so it was time to make decision about the interior. All black would be the easiest but not for a summer car. I was looking for something unusual but period correct. Finally I voted on the tartan/plaid interior, like Porsche did in the 70's. The more I see it the more I like it.
Original Porsche fabric is $$$ and none of them is for my taste, but tons of other colors are available. Finally I chose the original "Royal tartan", this package arrived from the UK a few days ago. Can't wait to see it.
Old June 14th 2013, 08:41
Bogara_ZO's Avatar
A bit off topic, but you might be interested in. A local oldtimer show with very different cars. Will upload my pics as will.
Official galleries:
http://galeria.totalcar.hu/magazin/2...urrpic=4363726
http://galeria.totalcar.hu/kozelet/2...urrpic=4364376
