A bit of excitement! Now I am ready for the soap box derby!! Just shove me down a hill!
![]() Although no cooling vanes in the rotors, I will switch the left and right rotors so the slotting is going the other way in order to be consistent with the back. ![]() ![]() Front clip isn't perfect but the front bumper and Kamei should hide it. The front was clearly in an accident at some point, and the fender bolt holes may need to be drilled out and welded back in. Maybe in the future I will replace the whole front clip. ![]() ![]() ![]() ![]() Watson StreetWorks wiring harness should arrive at the end of the week. My 944 CV's and axles are off for a little R&R, DTM cooling shroud will be coming sometime. Anyone have an idea what these sensors are? Oil Pressure???? ![]() Oil Temp????
You are correct with the sensors.
