Old August 10th 2013, 20:29
SportyBug SportyBug is offline
Originally Posted by fahrvergnugen View Post
The new (used) coilovers where in. I just had to try.
This needs some mods.
Are the mounting points for the trailing arms in the stock location? I've seen this problem happen before
Old August 11th 2013, 04:00
What problem?
The rear is narrowed by 19cm. I had to cut of the framehorns to place the mounting points.
Old August 17th 2013, 11:31
Started on the cage today. With these holes I can lower the cage a bid and weld the up side.
Bending the bends in the wright position and keeping it straight is a PITA.
Did you see my special cupper angle measure tool ;D
Paul.
Old August 21st 2013, 08:10
De first hoop is in.
I made the connection to the gearbox mount with tape, this way I can measure the angle I need.
Paul.
Old August 28th 2013, 15:56
Cage fight
Paul.
Old September 8th 2013, 07:14
DAMN, why didn't I notice this before. After checking the cage measurements, I found out that the gearbox wasn't in line with the middle of the car.
So time to start over again. (attempt nr. 3)
Paul.
Old September 9th 2013, 02:38
Noooooooo! Oh, you mean the tranny mounts, ok, I had a flash of you starting over on everything, just don't know if I could handle it!
Currently Active Users Viewing This Thread: 20 (0 members and 20 guests)
