Started on the cage today. With these holes I can lower the cage a bid and weld the up side.
![]() Bending the bends in the wright position and keeping it straight is a PITA. ![]() Did you see my special cupper angle measure tool ;D Paul.
De first hoop is in.
![]() ![]() I made the connection to the gearbox mount with tape, this way I can measure the angle I need. ![]() ![]() Paul.
Cage fight
![]() ![]() ![]() ![]() Paul.
DAMN, why didn't I notice this before. After checking the cage measurements, I found out that the gearbox wasn't in line with the middle of the car.
![]() So time to start over again. (attempt nr. 3) ![]() ![]() Paul.
Noooooooo! Oh, you mean the tranny mounts, ok, I had a flash of you starting over on everything, just don't know if I could handle it!
Paul.
