Old October 17th 2013, 00:30
graham's Avatar
graham graham is offline
'56 rag with a twist
Originally Posted by fahrvergnugen View Post
8 cm higher, it has become a short firewall
Paul.
Very smart
gee dub
Old October 17th 2013, 15:41
Originally Posted by graham View Post
Very smart
Thanks. This gives me more room for gearbox, engine and future plans
Paul.
Old October 23rd 2013, 15:39
Made the firewall a bit wider.
Wider piece it tacked in.
The difference.
fits pretty well
Paul.
Old November 6th 2013, 08:44
Firewall starting to take shape. The first weld are made.
Paul.
Old November 13th 2013, 16:38
Now we're flying.
Time for the final things on the chassis.
Old November 13th 2013, 17:06
Gerrelt's Avatar
Gerrelt Gerrelt is offline
Looking good!
Greetings!
________Gerrelt
________homepage:gerrelt.nl
Old November 13th 2013, 22:42
Coming along nicely!
Old November 14th 2013, 02:04
Rule09 Rule09 is offline
Very nice build!
Old November 14th 2013, 15:36
Thanks guy's. The end is just a few welding wire roll's away
Old November 15th 2013, 16:30
The R&P was only temp tacked in place when the body was on. Back then I had to ditch the sway bar.
Today I welded the R&P brackets in its final place, made new brackets for the sway bar, mounted the sway bar and R&P and made brackets to mount the body to the chassis.
Paul.
Old November 15th 2013, 17:18
Now the front is done, I started on the rear. The aligning is pretty good.
Paul.
Old December 4th 2013, 09:09
Not much progress lately. I am supporting son's football matches more than working on the beetle.
Made 2 holes to weld the cage mounting points in.
Dropped the body back on the pan and trial fitted the tubes that go to the gearbox. When these tubes fit properly I can start on the shock mounts.
Paul.
Old December 18th 2013, 16:50
Very small update.
Made some extra room for the gearbox by inverting the bent. Trying it look original
Paul.
Old December 23rd 2013, 16:55
My route is not always the easy route.
Vwrankenstein's notch will be made of original sheet metal. Even to close the gab, of the shortened firewall, i am using modified original sheet metal. I hope that when it's finished this will give an original look.
Paul.
Old December 24th 2013, 11:50
Gerrelt's Avatar
Looks good!
Greetings!
________Gerrelt
