Old October 31st 2013, 11:37
Bogara_ZO's Avatar
To make it as strong as possible the extra piece was hammered to a "hat shape" so it attaches under the fender's edge on both side. The outer side of the rear fender had to be shorten to keep the original shape and to line up with the running board.
Btw the +5 cm should be over on the limit where stock running boards can be used, at least mine looked awful (no pictures). The front section of the fender was sliced up again and got a "V" shape so the bottom edge is near to stock now and it looks ok to me.
After the second test fit it was good enough to go ahead, time to extend the bumper brackets (30mm) to clear the fenders.
This is it for now, I hope I get them back from the painter in a few days/weeks.
I will have to relocate the rear lights once the fenders are ready
Old December 23rd 2013, 19:32
Bogara_ZO's Avatar
November
Fitted the missing brake lines, hand brake parts, rotors, drive shafts, finished the berg style mid mount and the whole oil system with all the fittings and consoles
Old December 23rd 2013, 19:39
Bogara_ZO's Avatar
December
Old December 23rd 2013, 19:41
Bogara_ZO's Avatar
leaving the workshop
in the garage
next day
fitting the rear calipers
merry xmas
Old February 4th 2014, 11:21
Nice!
Old February 5th 2014, 20:49
SportyBug SportyBug is offline
Looks very nice. Do you have any pictures of your process of widening the front? I liked seeing how you got the rear to look right
Old February 6th 2014, 15:09
Looking really nice!
Old September 26th 2014, 03:34
Bogara_ZO's Avatar
Thank you guys. The front was easier as it is widened +2 cm everywhere
Old September 26th 2014, 03:50
Bogara_ZO's Avatar
It's been a while since my last post here, but i do have things to share (sorry for the huge pictures but my new blog stores them this way..)
So, new carpets for february:
Old September 26th 2014, 04:14
Bogara_ZO's Avatar
I changed my rear tyres from 215/45 to 205/45 as I needed more space for fender clearence.
Sidenote: Originally I was planning 205/45 as well but the PZero I put on the 8" had too much strech for my taste so I upgraded to 215. As PZeros are not available in 215 I bought a pair of new Conti Premium2s that seemed to be at least 225s or so when monted! Long story short I found that Contis are more robust, while Pirellis are more narrow than any other tyres in the same size. Finally I choose Michelin PilotSport3, it is said to be a very good street tyre on low weight cars (MX-5, Clio Sport etc.) and the 205/45 fits perfectly for the 8 wide rims, exactly what I wanted at the beginning.
Continental:
Michelin:
Old September 26th 2014, 04:23
Bogara_ZO's Avatar
Than came 6 month pause due to a knee injury Good opportunity to order the missing parts and to think about detailing.
In June I managed to visit the Bugrun in Sweden, Mantorp. Was a great event! Click for the pictures here:
https://plus.google.com/photos/10206...CM-y78Ly8M76bw
Old September 26th 2014, 04:48
Bogara_ZO's Avatar
July - back on working
Brakes are ready, the pedal is firm and both of brake and clutch operates well. Front is converted to studs so I can use same bolt on all wheels.
Sunroof is installed, works great.
https://www.youtube.com/watch?featur...&v=_i0qpD1hhXk
Old September 26th 2014, 04:54
Bogara_ZO's Avatar
Handbrake is working, door seals and trims mounted:
Door cards, tail lights, hood, rear bumper:
Old September 26th 2014, 04:59
Bogara_ZO's Avatar
Sunroof seals glued in:
Put together:
And adjusted:
Old September 26th 2014, 05:04
Bogara_ZO's Avatar
Working on wiring
Front lights and bumper installed (to be adjusted)
Rear is completed (except the bumper bolts), lights are working:
Steering wheel mounted, interior is coming along nicely
