Old September 25th 2015, 01:14
Just got back from the tuner.
Gone from 229 kW to 277 kW.
I've fitted Tomei Pon cams, Adaptronic 1280 ecu with E85 flex tune (it can run normal 98 RON unleaded), LS2 truck coils, larger up pipe, so its now making 277 kW, cant wait to drive it in anger, VW only 1/8 drag meet coming up in October.
The MAP sensor died on the dyno last night, so a 2 hour train trip home, borrowed a MAP sensor from my sons drift car, drove the tow Prado up with a trailer on and the tune was finished this morning.
I've done three road trips on E85 so far no worries getting it.
Old September 25th 2015, 10:09
Fiatdude Fiatdude is offline
377HP is very nice -- Well done -- My Ghia goes in for it's E85 tune at Westech in Mira Loma Oct 5th -- I don't believe I'll be able to match your number though LOL
The magic air pressure number for those Drag Radial is 10 to 10.5 psi -- That is where they really started working on my old Fiat (and other people's cars)
Old September 25th 2015, 17:33
Thanks for the tip, do they feel OK at high speeds with that little pressure?
Loving E85, motor runs 10-15 C cooler, thermo fan have hardly come on
Old September 25th 2015, 18:02
Yep no issues -- -- I would drive them on the freeways here at 70-75 mph with them down that low just because I was too lazy to fill them back up after racing LOL -- -- Don't know how they would work on a twisty course that low...... but there was defiantly a line there at that pressure where above it they would just spin and below they would hook, and everybody I know that has ran them has said the same thing
Old September 25th 2015, 18:43
Thanks Im only using them on straight line stuff, the Snowy Moutains 1000 is one car per run 1000 metre drag race, last year with only 229 kW I got up to 226 kph, this year I should go a bit quicker.
Old September 27th 2015, 03:39
Nice progress Steve!
Do you have a RPM calibrated dyno sheet as well? I am always interested at what hp combo's have at 4000 rpm ;-)
(what turbo did you use again?)
Old September 27th 2015, 06:16
Hi Wally
Its a GTX30/76R, I will see if I can get an RPM dyno sheet, these runs were done in 4th gear.
I think this is about as far as I can take this combo now, its a unopened low klm motor, we probably could have pushed it more but I really think I have enough power for a while, I want to do a few track days now and get used to the power.
If I wanted to go further I could stoke it, do some headwork and fit stronger valve springs.
Old September 27th 2015, 07:05
GTX3076R! Thats the new billet ball bearing from Garret, nice!
Its interesting as I use an equally size turbo from Borg Warner, but the cheaper plain bearing cast version ;-)
Power is at the rear wheels or converted to flyweel hp?
Tnx!
Old September 27th 2015, 07:30
Thats at the wheels, the turbo is one made to bolt onto a stock Subaru manifold
Old September 27th 2015, 12:32
Ah, is it a 'DOM3' (Blouch) turbo then maybe?
I had the old one of those.
277 kW ATW = about 433 hp flywheel (15%) at 1,65 bar boost.
Sounds much better haha!
Old September 27th 2015, 16:34
Hi Wally
This is the kit I bought http://www.rallysportdirect.com/shop...gtx3076r-turbo
Old October 11th 2015, 02:03
Photo with the Cookies, I prefer the look of my 18s.
I was down 3 psi at the 1/8 meeting, I didnt do very well, still getting used to the car, the Mickeys being so skinny needed a good burnout, lots of redlights. The launch control worked great, just fitted a B&M line lock so I will go and run the 1/4 soon at my local track.
Old December 4th 2015, 20:52
I went down to Cooma again and ran my Beetle at the Snowy Mountains 1000, it’s a bit like a drag race but only a single car at a time and at over 1000 metres on Cooma airport runway, it’s much longer than a traditional ¼ mile which is only 402.336 metres.
There was an amazing variety of cars running, even an electric Radical race car and a strong contingent of VWs.
This year I had a bit of completion in my class, I guy I work with ran his immaculate Datsun 1600 powered by a 350 kW SR20 engine, he was about 1.5 seconds quicker than me and took the class win, I came second. I finished at about 50th out of 135 cars.
This year I did few things to my car to make it run faster and I managed to go a bit quicker, last year my best time was 22.513 seconds @ 226 km/h, this year I did 22.3247 @ 236.7 km/h, I had 4 runs, two where I went from 2nd gear to fifth gear one were my coolant overflow sprayed onto my ignition coils and the one where I got my best time which wasn’t a very good run as it was late in the day and I had a lot of wheel spin off the line, so car is going great, driver needs more time doing angry gear changes. Can’t wait till next year.
A video of my least crappy run https://youtu.be/wQS_nG_2E_k
The VW/Audi times
SALLY-ANNE HAINS AUDI RS6 0:20.5470
SEBASTIAN NAJDER VOLKSWAGEN GOLF R 0:21.7327
STEPHEN MULLER VOLKSWAGEN GOLF R 0:22.1637
STEVE CARTER VOLKSWAGEN BEETLE 0:22.3247
GRANT HAYES AUDI S4 0:23.1235
MARCO MAK AUDI S3 0:24.0880
KEVIN ATKINSON VOLKSWAGEN GOLF R 0:24.4159
KRISTOPHER MULLER VOLKSWAGEN GOLF PIR 0:25.3367
TOBY FINDLAY AUDI S5 0:25.9065
MATHEW CAMERON SKODA FABIA RS 0:26.1783
WAYNE PENROSE VOLKSWAGEN KARMANN G 0:26.3953
MADELINE MOLNAR VOLKSWAGEN POLO GTI 0:27.3311
GLENN TORRENS VOLKSWAGEN BEETLE 0:27.9867
DARREN RANSON VOLKSWAGEN GOLF 1.4 0:28.2414
MICHAEL MOLNAR VOLKSWAGEN GOLF R32 0:28.3278
Old December 5th 2015, 04:29
Very cool event and great pics Steve! Congrats! 236 km/h is moving!
The 1000 meter distance is interesting as this puts it in the 'Landspeed racing' category.
If you also have the speeds with that last summery of all VW's that ran, my friend the vw landspeed historian Burly Burlile would be extremely happy
Walter
Old December 14th 2015, 08:31
The car feels very stable at these speeds, hopefully more speed next year.
a video of my best run which was still up the **** https://youtu.be/wQS_nG_2E_k
I just sent a list of results to Burly.
kph and times of above VAG cars
SALLY-ANNE HAINS AUDI RS6 0:20.5470 254.1 kph
SEBASTIAN NAJDER VOLKSWAGEN GOLF R 0:21.7327 232.8 kph
STEPHEN MULLER VOLKSWAGEN GOLF R 0:22.1637 238.3 kph
STEVE CARTER VOLKSWAGEN BEETLE 0:22.3247 236.7 kph
GRANT HAYES AUDI S4 0:23.1235 226.3 kph
MARCO MAK AUDI S3 0:24.0880 212.8 kph
KEVIN ATKINSON VOLKSWAGEN GOLF R 0:24.4159 218 kph
KRISTOPHER MULLER VOLKSWAGEN GOLF PIR 0:25.3367 209.1 kph
TOBY FINDLAY AUDI S5 0:25.9065 201.5 kph
MATHEW CAMERON SKODA FABIA RS 0:26.1783 196.5 kph
WAYNE PENROSE VOLKSWAGEN KARMANN G 0:26.3953 191.7 kph
MADELINE MOLNAR VOLKSWAGEN POLO GTI 0:27.3311 189.3 kph
GLENN TORRENS VOLKSWAGEN BEETLE 0:27.9867 178 kph
DARREN RANSON VOLKSWAGEN GOLF 1.4 0:28.2414 184 kph
MICHAEL MOLNAR VOLKSWAGEN GOLF R32 0:28.3278 181.2 kph
