Old March 2nd 2016, 17:03
subamaniac90 subamaniac90 is offline
986s brakes on 944n/a
Can i fit the front brakes of the boxster s(986) to the 944(pre86) n/a hub ? Except from the caliper adapter what other mods should i do? Thanks in advance.
Old March 3rd 2016, 16:39
I fitted them to Beetle stubs using 944 hubs
Old March 3rd 2016, 21:20
thanks for the info.
Old March 5th 2016, 17:01
effvee effvee is offline
Recondition the calipers
Hi Steve, Question did you recondition the calipers yourself? If so how are you able to recondition the Porsche lettering so nicely.
Old March 5th 2016, 17:59
I just painted the outside, so a rattle can restoration and lettering is a decal I bought on eBay, they have stood up to the heat very well.
Lucky I bought a few spare decals as they wanted to to stick to the backing and not to the calliper.
Generally Porsche callipers have stainless piston which don't corrode so I full rebuild is not always needed.
Old April 1st 2019, 10:52
Hello, just bought the calipers and discs. Do you have the adapter dimensions?
Thanks in advance.
Old April 2nd 2019, 21:19
flat flat is offline
Turn the early hubs down to 157mm and theyll fit the 986s rotor. I can make the caliper adapter but the axial offset can vary depending on how your 944 hubs were machined for t1 spindles.
www.vdubengineering.com
Old April 3rd 2019, 04:00
Actually my calipers are 986 2,5 base model. P/N 986.351.422. Spindles and hubs are early 944 N/A. By 157mm you mean the diameter of the hub?
Old April 3rd 2019, 04:21
Yes outside diameter (OD) of hub.
With the 986 non S caliper theres another option. Use a 84-89 911 carrera rotor (282x24) and itll bolt on like a 944na rear mount rotor(282x20) and match the boxster caliper width (24mm). I build alot of these setups because they fit 15" wheels, whereas the boxster rotor is bigger (298x24) and requires 16"
Old April 3rd 2019, 04:41
where I am the 986 rotors are half the price of carreras. Do the pads cover the whole carrera rotor area, or overhang a bit?
Old April 3rd 2019, 04:44
They cover. No overhang.
Old April 3rd 2019, 04:57
oh, I thought with carrera rotors, i would have to shave off some material from the pads. So what do you suggest? Wheel size is not an issue, i run 17s.
Old April 3rd 2019, 04:59
forgot to mention, on the rear i ve got 299x24 turbo discs with 996.352.422 calipers.
Old April 4th 2019, 10:47
Hey Steve,
Where did you get the 944 adapter bearings from? I may also need a set
TIA,
Walter
