Old July 26th 2018, 17:35
-Alex- -Alex- is offline
Billet type 1 heads
First pair of Type 1 billet heads are ready. These heads will go with 50x40 type 4 valves to street/strip 90x101.6=2919cc engine which will run with E85 fuel.
Second pair will be for my own 2789cc engine, with 18mm taller top fins and 48x38 with JPM valvetrain parts.
Both engines will use of course TF-1 enginecase
We will be using stock bails with billet valvecovers, but valvecover seal flange at bottom ends have smaller radius, this will make possible to have up to 54x40 valves with pauter rockers.
Naturally i have 94mm bore version and 6-stud version drawings too
Old July 29th 2018, 06:02
nice
Old August 8th 2018, 03:54
I 'v got the first time now the billet head to my own hands from my friend.
2mm thick and with 3mm gap the cooling fins look very good.
Ports have good size short side radius and very little porting to be done. At end of this year, heads will go the hearporter to get finished and for flowbench testing.
Tested Pauter 1.4 rockers and they fit very well, roller end of the rocker is at center of the valvestem.
Got one valvecover from my friend who made them with 3 Axis CNC machine, they fit very tight and bails work like on stock valvecovers.
Overall quality of the heads is nice, but i was hoping a bit improvement at machining quality if order my own heads from Elmer Racing later at this year, as they have better tools and experience. Material would be 6082 T651
https://www.facebook.com/ElmerRacingDotCom/
Only problem though, i need to buy 3 pairs at same time, to get price around to 2300€ per pair. Anyone interested?
I am sure that eventually price will drop more.
Valvecovers would be 300€/pair, either for stock bails or bolt on with M18x1.5 vent hose thread at ends.
Heads can be either 94mm bore or 101.6mm bore, ports for 48x38, 50x40 or 54x40 valves or specific setup. 54x40 choice needs exhaust valves moved outwards about 1,5-2mm.
Chamber on the 101.6mm head is about 55-58cc
Chamber on the 94mm head is about 50-53cc
Larger turbo specific chamber can be also designed invidually.
Old August 8th 2018, 03:58
Old August 11th 2018, 08:44
Flintstones's Avatar
Flintstones Flintstones is offline
WoW!! That looks amazing!
When do you think the motor will be together?
