Imhor Pedal Set
I know a number of us have been curious about the Imhor suspension products, and I'll perhaps start another thread with photos of my kit, but this thread is for the Imhor pedal set which I purchased.
https://imohr.com.br/en/products/41/...bly--vw-beetle These are definitely no replacement for a proper pedal setup that uses dual master cylinders, but if you're looking for a potential upgrade to the stock pedal set...these suit the bill. The kit assumes you have a late model beetle, and you'll be disassembling the stock pedal cluster and reusing a number of parts for this setup. The instructions are only in Portuguese, but are relatively straight forward and you can follow the photos basically. So far I've mocked them up in my '58 Beetle, and in doing so discovered a few things you may want to be aware of.
IMG_6134 by Dave Hord, on Flickr IMG_4528 by Dave Hord, on Flickr IMG_2492 by Dave Hord, on FlickrI also ordered the Imhor foot plates, but I'm not sure I'll use them in the '58. The driver's side could definitely be cut much closer to the pedals, but I suspect it's designed to fit over a stock pedal cluster as well as their kit. IMG_2927 2 by Dave Hord, on Flickr IMG_1679 by Dave Hord, on Flickr-Dave
7 months late, but how easy is it to change a clutch cable?
Looks cool anyway! |
No different than doing it with a stock pedal set.
The set is looking good, same as the other parts they have on the site.
But as far as I read in your review you would recommend it it you don't want to change to dual brake cilinders or hydraulic clutch?
VW Super Beetle 1303 1973 Kolibri Grün Metallic |
I would, yes.
Better than the stock pedal set, not as good as a full-racing pedal set. An excellent "in between" setup. Honestly, I don't have any complaints with it...except perhaps that it lacks the adjustability / setup options of my true racing sets. But that's me being nitpicky because I can set the clutch/brake/throttle angle exactly where I want it in some of the other cars...but not this one. Sigh, compromises :P -Dave
Dave--
I know this is an old thread, but I've only just seen it, and I recently started a thread on STF regarding pedals (well, at least pads) of this type. I currently have a "big boy" pedal mod that spaces the clutch over a bit (I have wide feet), but I'd really love to have pedal pads of this type. If this were compatible with the pivot shaft/throttle cable attachment, it might be worth a look. The pedal set up I have has a brilliant mod that uses a shoulder bolt in place of the hook, making the mounting of the pedal assembly VERY easy, using the factory throttle cable in such a way that it can no longer fall off as the assembly is located in the tunnel. I'm curious if you still feel the same way you did in your review from a couple years ago. I sounds like the Imohr assembly was designed to utilize the factory pivot shaft, thus SHOULD work with my pivot shaft, with a couple mods. Thanks in advance H2OSB
johnL (aka H2OSB) '74 1303, Outlaw sedan (with a GL flavor) |
100% feel the same way. Possibly might like it even more than my original review. I’ve put over 35,000mi on this particular pedal set this year alone, with zero issues.
Since it uses the factory pivot shaft, I suspect you could use yours (with its much better clutch cable setup). -Dave
In my defense, it's been a while since my car was assembled. Does your pedal assembly still use a roll pin to hold the pivot shaft in place? From the pics, it looks like the end of the shaft is threaded with a flat washer to hold it in the tube. Thanks H2OSB
One more question Dave. Do you feel there's plenty of space betwixt the pedals? The pics make them seem close-ish together, but I went to the Imohr website and watched the pedal set video. The pedals look far larger next to feet, vs pics without a frame of reference and thus perhaps plenty separated for my wide feet.
Also, assuming the spacing is as good as it appeared in the video, I found the clutch cable attachment upgrade is available in factory length ( actually I already knew...but now I've confirmed it) although a little spendy ($70 + $12 shipping). I would probably just drill a new hole and adjust the length if necessary, however. H2OSB
Sorry for the delayed reply. I'll grab a tape measure and fire up a photo in the next couple of days for you.
| Currently Active Users Viewing This Thread: 24 (0 members and 24 guests) | |
