Old March 7th 2003, 01:19
fweem1970 fweem1970 is offline
Unhappy Loc Tite
is there any thing that can remove a massive amount of loc tite i didnt relize how strong this stuff is i pored quite a lot in to my shift knob and now its stuck can any thig remove it?
Old March 7th 2003, 03:48
Richie's Avatar
Richie Richie is offline
You can try to heat your shiftknob with a paintstripper.
Put the shifter in a vice and as the knob expands from the heat you may be able to turn it loose with a thick rag wrapped around it.
It will take longer to heat it if you put the knob in the vice as the heat flows away through the vice.
Good luck and look out, don't fry your hands !
Richard
