How can I send you a picture of some?
Oliver,
I've got a series of pics of Ghias with obviously stock bodywork and Porsche Cup II wheels on them as well as Porsche brake systems. How can I send you some pics for you to look at |
I think the Cup II's are popular with Ghias.
I'm putting a set on of Cup II's on my Ghia now. I've got a whole set of 17" x 7's ET55. They all fit good. I'm going to try to stuff either a 9" rear or a pair of 8". I won't know what will be required untill I get the wheels. I've got a 2in narrowed/adjustable beam and drop spindles. I'm thinking of .5" spacers on each side to move the wheels back out. Since they hit the inner fenders bad. (I have pictures, but they're too big to post. )
Mike '04 R32 Tornado Red '02 New Beetle TDI - Daily driver '64 Ghia - Project!!-Subaru EJ20T, MS/EDIS, 993 brakes, 914 Tranny... Last edited by Mikey; December 8th 2005 at 23:48. |
Mike,
Here are some pics of my Cup II's, they are stock 17 x 7 boxsters. I tried giving you some idea of the space. Chris |
Thanks for the pictures, your Ghia looks Awesome. :righton:
It looks like a lot of room on the inside, but I'll probably run into the spring plate before I hit the inner fender. And if I decide to run Porsche brakes, I'll have to either narrow my trailing arms or buy some. (If I can't narrow them enough.) I measured my Ghia too. That's why I think I can fit 9's in the back. For them Not to fit, they'd have to hit both the spring plate and the fender lip. If they don't hit both at the same time, you can get the wheels moved in or out to make them fit the wheel well. It would be a lot easier to move the wheel out (spacer) than it would be to move the wheel in, but it can be done. Is any of this making sence? I'm no expert. ![]() *I forgot to mention, I'm building a '64 Ghia, which has lower rear arches than the late model Ghias. So the rear will look lower and MIGHT have more room. That's just a guess.
Mike '04 R32 Tornado Red '02 New Beetle TDI - Daily driver '64 Ghia - Project!!-Subaru EJ20T, MS/EDIS, 993 brakes, 914 Tranny... Last edited by Mikey; December 10th 2005 at 12:37. |
Finaly, I figured out how to resize.
The first 2 of my front after I put in a 2in narrowed beam, drop spindles, and adjusters. This is the lowest it'll go, I'll raise it up an inch or 2 for final ride height.The last 3 are after I put the rear wheel on today. I think it looks good, and I have no clue what possesed me into thinking a 9" would fit. A 9" rim with no tire maybe. The inside will hold a 9" wide wheel, but you run into the spring plate, then the shock tower. A narrowed rear tortion would fix that. But that's almost too much for a 2inch wider rim. 10"s maybe?... Either way. This is what I have right now. The back will settle a little more and I'll lower it more too. What you guys think?
Mike '04 R32 Tornado Red '02 New Beetle TDI - Daily driver '64 Ghia - Project!!-Subaru EJ20T, MS/EDIS, 993 brakes, 914 Tranny... Last edited by Mikey; December 11th 2005 at 22:54. |
looking good Mike,
I started out with drop spindles on mine too but the MBT brakes didn’t really look or sit right on the caliper, so I went back to the stock ones and a adjustable beam. I also installed a 1/2" spacer to bring the wheels out more. The rears I would leave alone, you know your going to get the urge to throw that GL Ghia into the corners and have fun , got to have some room for tire movement.If your looking for some hard to find parts, let me know I have sources here. Chris |
if you had any updates on your car? |
