Old April 25th 2020, 01:43
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Wally,
How much ground clearance do you have with the exhaust header setup the way it is?
Old April 25th 2020, 08:51
Originally Posted by DORIGTT View Post
Wally,
As the car sits now (I just measured for you) almost 5 inches (12cm). Silencer is a little over 4 inches..
Old April 28th 2020, 06:47
[/QUOTE]
Now I see which way it is going. Cool design
Old April 28th 2020, 07:54
Hi Wally
Looking good. Is that an OEM oil cooler or an aftermarket one? Does it fit behind the rear apron without any modification? I'm asking because I'm yet to source an oil cooler for my sons Beetle.
Old April 28th 2020, 14:27
owdlvr's Avatar
owdlvr owdlvr is offline
Wally, what do you use for lines for the oil cooler, and how have you routed them? -10AN I'm presuming?
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old April 29th 2020, 09:52
Hi Wally
Its apperently an OEM oilcooler, but its from a more obscure model (AMG?) Mercedes or so I understood. It has no part numbers, but I was looking for an upgraded one with the same M22x1,5 thread connections.
The guy in Poland had 2 or 3 of those...
It fits so snug directly behind the front apron and the spare wheel well, that I didn't even need mounting tabs or something! I just ty-wrapped it to both outer grill mesh holes
Oil feed from tank in the nose to engine is AN12. Oil suction and back to the front oil cooler and then tank is just 1/2" (13mm iirc) inner diameter oil line.
No problem like that for over 13 years now with all engines
Old May 2nd 2020, 07:17
For those that don't do FB or STF, I got the engine on the dyno yesterday and it did even better then I expected!
244Nm @6K and 226,5 CHP @ 7K with the low CR engine with air filters, muffler and horizontal fan belt running up to 8K made me very happy
https://www.youtube.com/watch?v=LKhbYc0gOGY
Old May 4th 2020, 18:21
nice
Old September 22nd 2020, 15:16
Just a pic from early this year just out of hibernation ;-)
Old September 22nd 2020, 15:30
H2OSB H2OSB is offline
Walter, I love your 1303
Granted, I am a bit partial
johnL (aka H2OSB)
Old September 22nd 2020, 16:41
Haha! Thanks man!
Old April 17th 2021, 03:41
Clatter Clatter is offline
Yep..
Just wanted to chime in that i read the whole thread again over the last few evenings.
Thanks for the inspiration.
Old November 11th 2022, 14:23
Haven't been here in a while, but for those still here: after the re-install of the whole turbo set-up, it made 475 hp at 1,6-ish bar boost on gasoline, 0% Ethanol, gas (the higher octane of course) bought at the pump here in Netherlands.
At Santa Pod I finally reached my long time goal and it ran a 10,58 seconds in the 1/4 mile at 130mph! Way more then I anticipated.
I drove there, camped at the track and drove back home again on my own wheels - as I had always planned.
https://www.youtube.com/watch?v=9LI-_7aQIIw
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
