Old August 23rd 2006, 16:05
zeroaxe zeroaxe is offline
Wiebrand,
Some nice progress on your car. Wish I could make progress as quick as you can. At the moment there is just way too much stuff that keeps me away from my car!
Anyway, I meant to ask about that ebrake of yours. Now that you have gone hydraulic with it, why do you still need the cables?(or am I just being REALY daft here!?)
Old August 24th 2006, 09:25
Racelook's Avatar
Racelook Racelook is offline
@ajsyrup;
Here's an link of the picturealbum with all the pictures I got from the handbrake. It's al welded together by ourself. And I use an 22mm HRC for it. If I make it the next time and have more money to spend I would use an smaller HRC that is maked for use on hydraulic handbrakes (needs less room then this one).
http://www.keversite.nl/fotoalbum/my_photos.php?id=1999
@Lurv;
There are verry verry much hours in it, don't know how much. But I worked on it for more then 4 years now. (I work on it almost every sunday (an half day) and 1 evening every week)
I still think it's going verry slow, but I don have so much time for it. Otherwise I was much further after 4 years, but yeah.
I need the cables for the yearly OT here in Holland. The handbrake have to be an undepended, lose system.
Wiebrand
B-Extreme B-Tuning.....
Old August 30th 2006, 18:15
Racelook's Avatar
Tonight found some time to work on the body again. In an hour a third of the spare-tire-piece-of-metal was cut out. Tommorow more.
Wiebrand
Old September 13th 2006, 17:20
Racelook's Avatar
Last week sandblasted some pieces of the spare-tire-thing.
Tonight found some time. And after 1,5 hour of cutting, grinding and welding it looks like this.
Wiebrand
Old September 14th 2006, 10:51
ajsyrup ajsyrup is offline
interesting setup are your intentions for that as an e brake. or is it more of a cutting or turning brake appliction just curious great work all around though car look amazing
Originally Posted by Racelook
@ajsyrup;
Old September 15th 2006, 06:36
Racelook's Avatar
Is more for cutting and turning brake "corners" in the future (maybe some histo-rallys), but it can also be used as daily e-brake.
Wiebrand
Old September 18th 2006, 11:16
Wiebrand
another stupid question i just thought for safety purposes an e brake should be cable driven not hydraulic just curious cause i am in the progress of my brake setup and i tell would be hell of a lot easier to do hydraulics then cables just curious
thanks for answering all the stupid questions
Old September 18th 2006, 18:09
Racelook's Avatar
No thanks mate..
See my answer on 24 augustus. For safety and OT the e-brakes have to be seperatly and not dependent of each other. Mine are not seperatly, so that's why I have to use the cables ones a year. For only e-brake use it doesn't matter if it is hydraulic or cable. Cable is much easier.
Old October 10th 2006, 04:27
Racelook's Avatar
So there some update again.
The sparetire-platework and the strenghtening bar is in. Also checkes several previous weldings (some cut out and welded in again). I also started with welding close almost every hole in the dashboard-platework.
The backplate (where the exhaust goes through)didn't fit quite good, so had to hammer verry much, but now it finally fits good.
I have some pics of it and will post it soon.
Wiebrand
Old October 18th 2006, 01:11
alt+f4 alt+f4 is offline
I know you are bussy like most of us, but any new pictures?????
Thanks man Keep it up!!!
Jon
Old October 20th 2006, 11:04
Racelook's Avatar
Finally some time to update here.
This is form last week thursday (12th of oktober).
Had made some metal on size and welded close several holes in the dashboard-platework.
And some pics of the work from wednesday the 11th.
_checking the rearpanel
With much knocking it will become 1 cm wider at each side http://www.keversite.nl/fotoalbum/fotos/40523.jpg
-And an total pic of the spare-tire platework.
-And controlling all the welding. And that are some meters in this car
http://www.keversite.nl/fotoalbum/fotos/40525.jpg
Buntje
will update soon
Old October 22nd 2006, 07:09
Racelook's Avatar
As mentioned before I also worked on the car on thursday the 12th.
Welded an plate in the sparetire-platework and controled weldings at the dashboard, a-pillars and heaterchanels
An pic of the sparetire-platework from the underside
Old October 22nd 2006, 08:31
jonas_linder jonas_linder is offline
Very nice work Keep it going
Old October 22nd 2006, 17:40
Racelook's Avatar
Thanks man...
Any updates on your car/engine??
Today also welded some hours on mine car.
De B-pillar and some holes in the rear(side)panels welded close and also started with making an air-intake from an flat panel for the enginelid.
Wiebrand
Old November 6th 2006, 19:56
Racelook's Avatar
After a lot of days with short time, I finally had some time last sunday to work on my car.
We started with making an airscoop for the enginelid. TO first have an cleaned lid, we welded some holes closed, and cut out al the represt pieces, maked some new plates and welded them in. After that the hammering begun to make the sides of the airscoop. They're both finished and one already welded on the lid=> see the pictures.
From the rear
Also are the holes were originally the heating-tubes are mounted welded close.
http://www.keversite.nl/fotoalbum/fotos/41701.jpg
Wiebrand
