Old September 11th 2009, 19:18
Clatter Clatter is offline
I'm doing a GL T3, and it appears that the aluminum arms will increase the rear track too much.
No big deal, just use 924/944 N/A arms, axles, stubs.
Unless you want to flare the fenders...
Or chop the torsion housing and tub it, or something radical..
Old September 12th 2009, 03:01
kombi211 kombi211 is offline
that what i need is a wider track on the arm i have 16 phone dials off a 928 with a offset of 65 and running a thick spacer already 20mm with those arm i will almost eliminate the need for the spacer i hope just have to wait and see i guess...
Old February 11th 2010, 08:02
started doing the front brakes now
hubs machined
bearing adapter and sleeve using vw inner and 944 outer
vw race installed
vw inner bearing and 944 outer bearing
test fitting hubs and rotors
test fitting calipers to see what i need to made for a adapter to mount them
used the mounting tab off of a set of 944 spindles just welded them to the stock vw spindles
