Old January 24th 2006, 16:17
I think something must be getting lost in the Babblefish translation. Maybe I should just be posting the finished product and not the build up.
IT IS NOT FINISHED. When it is done it will be very safe and very strong.
Old January 25th 2006, 12:38
rip's Avatar
rip rip is offline
looking good
just an idea instead of going up to the dash again for the front mount maybe mount it into the wheel wells. a lateral bar spaning the two. this way if you wanted you can make it double as a shelf like cover it with one of the bambo/straw shelfs = very sleeper
Old January 25th 2006, 14:57
Originally Posted by rip
looking good
I really like that idea, but as you can see from the pics I've got speaker pods in there that I really don't want to have to redu. As well, the bar would be a definate shin breaker in a severe accident, and would also be a heck of a lot heavier and require more holes to be drilled. I do think if I had a full cage that is EXACTLY what I'd do though.
I got these high strength stainless T-bolt clamps from a local hydrolics place. I'm planning on using both of them on the steering column to clamp a bracket onto it. I should have the whole thing done this weekend, so look for some new pics then.
Old January 28th 2006, 22:24
Finally figured out what sort of bracket would be the lightest, easiest, and strongest.
Old January 28th 2006, 22:28
I got a little carried away with the weldling, as I havn't got the MCs in there yet and there may be a small clearance issue. It's possible I'll have to do just a regular piece of bar, not the one with the fancy holes, as there may need to be some grinding to clear the MC.
Here's the J-bolt clamps. Apparently these are very strong and I'm using 2 just in case one were to fail.
Old January 29th 2006, 13:11
jonas_linder jonas_linder is offline
Thumbs up
Looks great Jason! :agree:
Old January 29th 2006, 17:18
starmember's Avatar
nice solution. :agree:
90 in to te corner.
Old March 14th 2006, 02:24
Finally got the master cylinder. Was supposed to get 2, but as usual there was an order mix up. But I was able to install it and I JUST have enough clearance between the MC and the bracket.
These are the rotors I'm planning on using. Just over 12" in diameter and .83" thick.
Here is the new MC at home.
Old March 14th 2006, 17:38
Mikey's Avatar
Mikey Mikey is offline
Superb quality.
Keep the updates coming.
Mike
'04 R32 Tornado Red
Old March 14th 2006, 23:02
Really nice looking... One question though
Is it going to be legal with the M/Cs there? I believe its a safety matter thats why im asking. In Europe this would make the car illegal, since the driver can hurt himself ( that would be by impact on the knee area during an accident) on some part of the vehicle ie extruding parts from the under dash
Chris
Aircooled 4ever
1973 1303 going towards GL
Old March 15th 2006, 01:16
Chris
Interestingly enough, the safety was the very first question I worried about when I had the idea of the reverse mount. I'm not exactly thrilled with the location. I'm going to be putting a cover over the whole thing that has foam in it but quite honestly, if I'm hitting something hard enough that I'm getting near that with my knees, I've probably got some other problems as well. Bugs aren't exactly safety icons, and I'm not planning on changing that too much, but I'm hoping that the fact that I'll be able to out-brake and out-handle any other bug on the road will put me up a notch in the safety department compared to a stock bug.
Old March 15th 2006, 21:10
zeroaxe zeroaxe is offline
Question
Originally Posted by volkdent
Good job on the install! Plenty of ideas to be had here. I was just wondering if the mount would not flex on either of the front corners with your fancy bracket in the middle? I would wonder if it might've been a little better to have two thinner (fancy)brackets extending from the corners of the front of the bracket towards the steering column?
Then again, that assembly might be MUCH stronger than what it looks like in the pictures
Just my €0-02
Old March 16th 2006, 13:56
I know it looks a little fragile, but it is in fact very strong. Though it doesn't look it, it's actually triangulated in three dimensions. The rotational forces that would be controlled by the "fancy brackets" are already being handled by the back 2 edges of the frame and the front single bracket is only left to handle vertical forces. The pedal assembly itself actually strengthens the whole thing too. I've stood on it with all my weight and I didn't notice any movement whatsoever. BTW, I weigh about 240!
Old May 6th 2006, 02:20
Finally got all the brake lines! Had to have a couple custom flex lines made with banjo fittings that will reside on the ends of the MCs. Calipers are no farther along, looks like I might just have a set shipped directly from RPI Equipped to Lanner. What a PITA! At least now I can get all the lines run leaving just the front calipers to arrive and be bolted on. Slow and steady wins the race? We'll see...
Old May 6th 2006, 03:12
Mikey's Avatar
I know how you feel. 1 step at a time.
Mike
'04 R32 Tornado Red
