Old December 4th 2007, 15:37
gsusmaniac gsusmaniac is offline
What kind of wilwood setup is that? I have thought of going to a different pedal design but havent really looked into it yet!
Old December 4th 2007, 16:35
It's a reverse mount setup. You can read more about it HERE.
Old January 21st 2008, 17:44
Originally Posted by Hoghead View Post
Could you please send me a copy of your throttle pedal design
rgstraghan@yahoo.ca
I live in Thailand and machine work is very cheap here. While perhaps not the cheapest in Thailand, I know an American with a CNC machine shop about 50 km form here. China might be marginally cheaper, however there is the IP question, and margin for the middleman.
If there is group interest in producing a small run of parts, I am willing to coordinate it. I am retired and do not need to make my living on things like this and will do it simply for the benefit of the group at cost.
Robert
This is a scan of the printout of the original scan of the part. Unfortunately, the original scan was lost when the computer crashed, but at least I had made one printout.
It should be close to 1:1, but if it needs to be sized, keep the aspect ratio and make the width of bottom part of the pedal 4".
Throttle Pedal
Old January 24th 2008, 21:23
bengod
Thanks for the scan volkdent.
I cut this out in card board and overlaid it on my stock pedal. Looks to accommodate a 12 wide quite nicely.
Thanks again.
Kenney
Old February 28th 2008, 02:02
mccarthy500 mccarthy500 is offline
so does anyone else have any home mode parts? the pedal is pertty cool i like the idea.im in the proccess of making my own kafer brace. right now i have all the measurements done but im waiting on the clevis rods i ordered from jegs. does a kafer brace count as a home made part? if yes then when i'm done i will post it here.
Old February 28th 2008, 15:26
1303R's Avatar
1303R 1303R is offline
my whole car's pretty much home made, filler, gaffa tape...... prob why it's always in bits
Old February 28th 2008, 15:37
I think anything you had to actually make from scratch is a home-made part, from a custom wire holder to a carbon fiber dash!
Old February 28th 2008, 15:40
1303R's Avatar
ok well here's my home made dash, full of expandy foam and filler
Old February 28th 2008, 15:44
1303R's Avatar
before filling it up with expandy foam
and after smoothing out with thin layer of glass fibre filler then body filler and matt black paint
Old March 9th 2008, 14:53
KAFUR1's Avatar
KAFUR1 KAFUR1 is offline
i like it...
Old March 9th 2008, 22:57
1303R what kind of peddles are those?
Old March 10th 2008, 00:16
Looks like simple aluminum plate that's been drilled...
Kafer_Mike
Old March 10th 2008, 13:27
1303R's Avatar
yep aliminium sheet drilled and countersunk. pop riveted on, steel rivets they look pretty cool for the cost. added couple of strips of clear skateboard grip tape to the brake and clutch pedel as they were no good with wet feet
Old March 11th 2008, 12:25
Looks good. Proof form and function don't have to cost big $$$...
Kafer_Mike
