Old October 22nd 2006, 21:06
yep mine was that thick on the bottom. I bought it off the self and brought it home and broke 2 stirring sticks before I closed it up and took it up to lowes for a good shaking. Like I said, it is spray on bondo. You will need a big tip in your gun to shoot it.
Old October 23rd 2006, 20:04
yellow73's Avatar
yellow73 yellow73 is offline
Yeti,
Glad to hear that you are still at it. Yours is going to be an awsome car, thanks for the updates!!!!
73 Type 1 - 2270 Type IV
64 Type 34 - 1500 Type III
Old October 23rd 2006, 20:16
yetibone's Avatar
yetibone yetibone is offline
It's a good thing that primer was all gooped up in the bottom of the can on Saturday...
I just got off the phone with the fellow that painted my TR6. After he got my gallon of primer back to a homogenious liquid, he talked with the Evercoat tech rep regarding Slicksand's adhesion to acid based etch primer...a question I had after reading the label.
Turns out, it won't stick. Since Slicksand is polyester based, it cannot get a chemical tooth into acid based primers, like body filler, and glazing putty can't. After curing, I would'ive been able to peel it off in sheets from anywhere etch primer is underneath.
So sometime before next weekend, I'll pick up some plain old 2K urethane primer.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old October 23rd 2006, 20:19
yetibone's Avatar
Originally Posted by yellow73 View Post
Yeti,
Thanks Nigel. I do intend to turn this heap of anger and frustration into a drivable car one day.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old October 23rd 2006, 23:27
Will it bite the 2K after a coat of that?
Old October 24th 2006, 06:55
yetibone's Avatar
Yeah, but they said I don't need to build the surface up that much if everythings already level, and featheredged.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old November 30th 2006, 19:16
yetibone's Avatar
Ok. I've 2K primed the outside, dry 220 grit blocked it all over, Slicksand primed it inside, and outside, and should be able to start blocking to finish this weekend.
Dave, you were right about the buildup of that primer. It's so thick I could hide some of the interior seams with it.
I've still got to decide on a color, but it'll be a couple of weeks to get my money right for some paint.
*After this, I'll post update threads into their corresponding forums.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old November 30th 2006, 20:13
Yep that stuff is sray-on-bondo. It won't shrink and cures very hard. In fact you better start blocking right away or it willget very hard to block. I did 3/4 of Ryan's bug the day after we shot it and waited 3-4 days to finish the other 1/4 and it took me longer to fish the last 1/4 than it took to do the first 3/4.
Old November 30th 2006, 20:49
yetibone's Avatar
I agree. It's been 5 days since I laid that stuff down, and it's almost too hard to block with wet 320. I've found that using dry 180, or 220 works great to take it down to just above the bottom of the orange peel, and then wet sand it the rest of the way down to the bottom of the orange peel, taking out the dry 180, and 220 paper scratches at the same time. Yesterday evening I got the front decklid ready to paint in an hour and a half that way.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old December 1st 2006, 08:55
Looks like I forgot to tell you that part. I wish I had finished blocking Ryan's in the first 2 days. As far as "high build" primer goes, I love that stuff.
Old December 1st 2006, 18:24
yetibone's Avatar
No, you DID tell me that, I just wouldn't have been able to start blocking until days later 'cause of having to do other stuff.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old December 8th 2006, 22:17
yellow73's Avatar
Yeti,
Great to see the progress....have you thought about Texas Yellow for a color......
Old December 9th 2006, 18:29
yetibone's Avatar
Yeti,
Actually, BMW Motorsport yellow crossed my mind...but the TR6 is already that color as a base. It's a not-too-bright, not-too-dark kind of yellow that gets your attention, without burning your eyes.
At the last minute while mixing the basecoat for that, Gunter says "You want some pearl on top of this? You know...3 stage and stuff?" I said "#*@% yeah! Lets do this." So what I ended up with was a color that Gunter calls 'Silver Queen Sweet Cream Corn Yellow' which I've grown to like considerably.
At this point, I think the Bug will either be some shade of blue, or some shade of silver.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old December 14th 2006, 01:06
Mikey's Avatar
Mikey Mikey is offline
Nice progress, I can't wait to see the final product.
Mike
'04 R32 Tornado Red
Old December 19th 2006, 20:23
yetibone's Avatar
I can hardly wait either.
I took in a side job for some Poorsche fundage. The gent with the '79 Westy I built an engine for this summer has employed me to overhaul a donor front axle to replace his rusty one. He also wants to install the L-Jet fuel injection on his Westy from the same donor Bus.
That should give me enough to buy the paint, bumpers, body and window seals, and maybe taillight covers too.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
