Old February 13th 2005, 20:38
yetibone's Avatar
yetibone yetibone is offline
Where I'm at so far...
A few pics of the 1303 pan and stuff
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 13th 2005, 20:42
yetibone's Avatar
Mo' pics...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 13th 2005, 21:46
looking good yeti
btw, what are those stabilizer bars that you welded on the the
lower control arms?
Old February 13th 2005, 22:15
yetibone's Avatar
They're diagonal links with heim joints at the upper ends. They keep the horizontal control arms from having to rely on the sway bar to control caster, like a radius arm would.
They are only tacked on in the pics. I've made the pieces to box the whole arms in with, top and bottom. I'll weld them at work tomorrow.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 14th 2005, 05:18
Sure could have saved a bunch of time welding that 911 front end I have in place.
Looks good Joe, gonna have to come and see it soon.
63 356b time capsule
948 project
Old February 14th 2005, 06:50
A pre-964 front end is less high tech than a Mc Pherson 1303 front end
The extra control arms with heim joints look a lot like a set-up I saw many years ago on a german Kaefercup car..
Looks very good!
PS: Jurgen, did you ever come to informing about shipping costs of the 912E tach we talked about?
Old February 14th 2005, 13:11
randyj randyj is offline
What transmission is the crossmember for?
Yetibone,
That is a really sout crossmember you have there. What transmission is it for?
Randy
Old February 14th 2005, 13:29
yetibone's Avatar
Originally Posted by randyj
Yetibone,
Randy
914/901. I made it from 6061 aluminum.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 14th 2005, 13:35
Mikey's Avatar
Mikey Mikey is offline
It looks great, I love that crossmember, looks more professinal than mine, 3 peices of flat bar, and a peice of square tubing.
Great looking pictures too, I love to see projects in progress. Keep up the good work!
Mike
'04 R32 Tornado Red
Old February 14th 2005, 15:06
Dude got mad skills. :agree:
Old February 14th 2005, 15:38
Racelook's Avatar
Racelook Racelook is offline
Looks verry verry nice...
I like what you made on the front of your car!!!!! I hope it support for the right task.
Greetings Wiebrand
p.s. I shall not copy it
B-Extreme B-Tuning.....
Old February 14th 2005, 19:45
yetibone's Avatar
Greetings Wiebrand
If you copy it, I won't mind. No patents on anything. I just didn't want the caster changing as the suspension jounces, or if I hit the brakes hard and turn in. This way, the horizontal control arms track straight up and down, and not in an arch. Plus, with this geometry I can actually ADJUST caster wiff the heim joints.
The 2 piece shiftrod is the big thing. I wanted to make the 901 shift right in my Bug. I got two 1" OD universal joints, one 12" behind the shifter, and one at the selector shaft on the gearbag, to work with the mis-alignment of the selector shaft and the base of the shifter. Everything else is pre-72 911 stuff.
It shifts SO SMOOOOOTH!!!
Thanks for the kind words fellas, I'll keep yall updated and try not to be such a stranger 'round here anymore.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 14th 2005, 20:56
So let me get this straight, Yeti, your using 2 universal joints instead of welding on length and bending a Z into it. That sounds a lot like the what VW did with the steering linkage on the '71-'74 supers. I'll considering that for my setup.
Nick
Old February 14th 2005, 21:03
yetibone's Avatar
Nick
Yep. That's what I did. Here's a link...
https://sdp-si.com/eStore/Direct.asp?CP=Index.htm
That's where I got the joints. P/N A5Q 8-D516.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 15th 2005, 10:43
Thats exactly what I am working on .. I've got the shift rod welded up with the U-Joints and used a Bug shift rod shortening kit on one end of the shift rod for adjustability. By the angles involved, I don't see how putting a Z bend in the rod would work, let alone shift smoothly ... the 2 u-joints are definately the way to go.
Project looks great !
