Old December 28th 2005, 16:31
Let There Be Brakes!!!
I'm starting on the brakes now. I already have the RPI Equipped!(now defunked) Wilwood DynaLight 4 pots for the rear, as I got the whole kit for cost, and for the front I'm thinking another set of those or maybe some 6 pots? (I know, I know, Lazylongboarder is wearing off on me) but I can get them for cost as well so why not?
Anyway, today I purchased this Wilwood pedal assembly. It's reverse mount so I hope to be able to make it work, but I really need to have the pedals in my hand to fit them. I got them for $160 plus about $13 in shipping from Ebay, and Wilwood lists them for over $200 w/o shipping, so I'm feeling OK about that.
Old December 28th 2005, 17:46
Panelfantastic's Avatar
So lay out the design plan... reverse mount? you gonna hang'em? or try to adapt to a floor mount? resevoirs inside or outside?
I've seen some really cool pics of race cars done both ways. Gonna be sooo cool!
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old December 28th 2005, 19:43
Hang reverse mount. I'm going to fab up a bracket that attaches to stock points and I'll have to drill a couple more. Remote reservoirs under the hood. Brake bias bar with remote adjustment for now, and if I need it an adjustable proportioning valve to the rear. These pedals are the shortest ones they have with a 5.1/1 ratio. I asked Wilwood and they said for our little cars that ratio should be fine, and it gives me a little more space for pedal travel. I really don't know if those pedals with fit until I get them there, but they are just over 10" long at their longest, so I think that should fit under the steering column. We'll see!
What about T's for the system, should I just use the stock T's or is there something else I should look at?
Old December 28th 2005, 22:12
The only thing I've ever seen with hard lines are those brass or aluminum block style... pick up a Street Rodder mag at the newstand, there are several companies listed that do nothing but brake hardware.
I'm in the process of upgrading a few things on the bus myself. Nothing as glamourus as your stuff, changing over to dual circuit M/C and adding a bias valve... are you planning to use the knob style or lever?
Jeff-
VKG Bastage child
Old December 29th 2005, 03:46
Jeff-
That's a little personal isn't it? I think knob, from what I understand it's infinitely adjustable while the lever has detents, but I could be wrong. According to the Wilwood guys, I should only get the proportioning valve if the bias bar isn't enough adjustment.
What sort of ends do those steel lines need anyway? I heard SS lines have to use some special pressed end or something. I havn't had any experience with brake system construction, just OEM type replacement.
Old December 29th 2005, 11:23
Educate me a little... bias bar means you have independent cylinder and resevoir for the front and rear and the bar limits pressure on one or the other?
Pressed end? Not sure about that either. They do have a specific flare (degree amount) on the ends but that's all I was aware of...
It would be really cool looking if you could use braided everywhere but of course that's a big no-no and a wee bit pricey.
Jeff-
VKG Bastage child
Old January 5th 2006, 20:31
tommi_nylund tommi_nylund is offline
Which master cylinders you will use??
Wilwood´s or something else??
Old January 5th 2006, 22:45
Wilwood is saying 1" diam. for front and rear for the master cylinders and then the balance bar in the pedal assembly for tuning. I will probably not go 6 piston, as they are almost twice as heavy as the Dynalite 4 pot. If the Dynalites on the rear have 1 3/8" pistons, I'll be using 1 5/8 pistons on the front, but I have to reasearch as to what I actually have in the rear right now, they came as part of a kit I ordered and I don't know exactly what they are.
Old January 16th 2006, 15:20
rip's Avatar
rip rip is offline
volksdent
I resently did a wilwood triple firewall setup seen here
2nd gen Rx7 4 pots up front
single piston ford tarus sliders in the back
using 3/4 front mc
and 7/8 rear mc
also using 7/8 clutch mc
people say to use a 3/4 clutch mc but it was still a bit of movment I like the 7/8" better
oh and btw the last pic was without the pedals adjusted.
Old June 21st 2006, 08:49
ajsyrup ajsyrup is offline
what throttle set up is used in the picture? is that something purchased or your was it custom fab? or is it just a modified stock pedal set?
volkdent what throttle pedal do u intend to use?
also anyone ever messed around with the floor mount wilwood pedals i looked at a few in a pro truck over the weekend and it seems possible.
Old June 21st 2006, 11:48
The floor mount is possible, but I think it will require a false floor and moving the seat back quite a bit.
I'm having a custom pedal built that bolts in to the stock pedal assembly holes as well as the stock MC holes for support. I'm not getting to far with the guy I've been working with, so I may just draw it on AutoCAD and have someone mill it out for me.
The pedal in the pic is an aftermarket roller pedal.
Old January 16th 2006, 15:29
rip's Avatar
rip rip is offline
oh yea also I made up a excel spreadsheet similar to the one tiltons uses to calculate the mc sizing if you want me to run some numbers lets me know.
I would need things like those in the attachment
many of the things I've already figured like pedal force and the measurements of the pedal assembly.
but tire size and specs on the brake calipers are definately needed.
let me know
rip
Old January 16th 2006, 15:43
rip's Avatar
rip rip is offline
some samples of the outputs
Old January 16th 2006, 16:46
Thanks for the info!
Are you going to build a false floor to get your feet up as high as the pedals are? I was just checking out the Stasis Engineering Speed Touring Car A4, and they did just that with some aluminum.
One way or the other, it looks like your going to have to get your clutch and brake pedals near your gas pedal. What is your plan with that?
I might have some time today to try to position those pedals today and see how they'll work. I'm going to be using remote reservoirs to make fluid access easier.
Old January 16th 2006, 18:36
rip's Avatar
rip rip is offline
actually with the new seats in the pedals arn't that bad, i'm pretty tall with 12.5 size shoe.
but I was toying with the idea of simply extending the pedal surface a little bit lower. this is easier than the false floor. Not to mention ever try to get into a bug with a false floor? not to easy for taller guys. the steering wheel hits the legs when getting in.
But please keep us posted I was thinking of getting the reverse swing wilwood pedals but thought it would interfer with the steering column too much, that they would hit too low on the foot, and push the pedals too close to the driver. not to mention it seems like you have to build a semi cage to hold them. if you already got a cage no problem, but needless to say a few little things were discouraging me with that setup.
The problem with the firewall setup is like you mentioned the hieght. but if you build new pedals and just use the mount for the mc. you can increase the pedal ratio and drop them further. just gotta rethink the mc size then. but its all fun.
rip
