#1471
. Looks good to
#1472
In the meantime...
I had it on the dyno ![]() ![]() https://youtu.be/G1FPuZj_lwk Pretty decent result, although I had hoped for even a little better. ![]() Atm, the topside (intake, exhaust) has been removed in order to upgrade the clutch and to make the turbo primary twin-scroll header. Turbo has found its place as well: ![]() ![]() So far for now. |
#1473
Great to see it back on the road Wally
http://www.ricola.co.uk |
#1474
Hey Walter, how much boost? What are the graph in good old American horsepower. I see that you have utilized your inside parcel tray, now you got some more room right on. Double disc four puk question why not the 8 puk? Will the engagement be more harsh for the street. Is your build transforming more toward pure track and race? That flywheel/clutch looks like it means business.
Right on, looks NICE WALTER http://s86.photobucket.com/user/effv...l?sort=3&o=112
#1475
2000 US horsepower
#1476
Wow
#1477
IIRC, 4-puck is all Tilton sells these days. The former shape of full disk which had 6 divided parts on the disk, just isn;t available anymore.. The centers are stronger too btw, with 8 instead of 6 bolts iirc, so more little changes have been done to the design at Tilton.
I'll just trust them to know what they are doing ![]() Just reinstalled the Cup brace and for the first time, the scatter shield I had made a while ago already (needed for certain tracks here):
#1478
Building the header over the holidays
#1479
Very nice Walter.
#1480
Mythbuster: continuing project thread of my 1303 '75
This car just gets better and better
gee dub |
#1481
Wally, any other pics of the new transmission mount? It's my next project on my build, after I get caught up around the house.
#1482
Walter, what size are your header tubes.
#1483
Francelle: they are 39mm inner diameter and 42mm outer diameter (1,5mm wall stainless 304).
Still on the large side for the engine size and anticipated power levels, but its what I could get the parts for most easily and the same size as the former 2,2 engine had. I'll try and look up some other pics of the tranny mount and combined scatter shield. Its basically the steel upgrade engine lower mount from Gerd Weiser (GWD.de ,others sell it too), where I have flexed off the flat part and substituted it with 10cm wide and 6mm thick plate to serve as a scatter shield. Its protocol here to enter dragraces if you drive under 11.99 iirc... |
#1484
Intake building this WE:
#1485
Can’t wait for the new numbers!
If I could just get paid for my sleepless nights.... 1960 VW Bug UBRDUB Walkaround 1st Drag Run Dyno Run Oval Ragster-'57 Rag/'04 Boxster S |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
