Old May 14th 2009, 15:53
tom'72's Avatar
tom'72 tom'72 is offline
how to fit handbrake to porsche brakes?
Here's my setup
stock vw bug hubs machined to fit porsche 996 GT3 discs and calipers.
Now the problem is, I have no idea how to make the handbrake work with this setup, I'd prefer not to go with a hydraulic handbrake if possible.
Does anyone have any pics or helpful info on how the handbrake setup works on a 996 GT3.
Any help is appreciated really.
pics of the setup:
Front
rear buildup pics
Old May 14th 2009, 18:09
One option would be to fit an aftermarket handbrake conversion kit. Marlin (UK kit car company) have a patented one that should do the trick
Old May 15th 2009, 03:05
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
http://www.isa-racing.de/20091/webseiten/Seite-081.htm
Old May 15th 2009, 05:58
How wide is the disc (rotor)? You might be able to use a Wilwood mechanical caliper: http://www.rallydesign.co.uk/product...oducts_id=8312
Alternatively fit a plain disc between the inner CV and the gearbox and mount the mechanical caliper on a cradle over the gearbox.
Old May 15th 2009, 16:02
tom'72's Avatar
Thanks for the info guys.
I've emailed Marin about their kit, seems to be the best and easiest solution.
I hope they'll be able to help me out.
Old May 19th 2009, 15:44
tom'72's Avatar
Unfortunately Marlin doesn't have a suitable kit for me so the search continues.
Old May 19th 2009, 17:03
Xellex's Avatar
Xellex Xellex is offline
Going through the MBT catalogue, after I saw the MBT 1303 that Wally posted, I noticed this pic. Maybe they can come up with a similar setup for you.
www.vw1303s.com
Old May 20th 2009, 13:26
From memory it was an incredibly simple design that I´m sure you could do as a one off...
Old May 21st 2009, 11:34
tom'72's Avatar
I'll try to find some good pics of the kit, maybe I can have something similar made up locally.
Old May 22nd 2009, 04:45
Simon Simon is offline
That looks like the Brembo handbrake caliper used on expensive (super)cars, which not only weighs more than 2 kg but also costs more than $ 200 :/
Old May 23rd 2009, 08:43
What about getting a simple caliper from the rear of a Mazda etc that has handbrake setup built in.
Old May 23rd 2009, 13:45
tom'72's Avatar
The main problem will be (just like with the willwood setup) that the disc is very thick and the caliper will not go over it?.
I'll have a look at the wreckers to find one?
Anyone know of other car types that use a caliper for a handbrake?
I know Aston Martin uses it but price will be high I think.
Old May 23rd 2009, 14:15
Arnoud's Avatar
Arnoud Arnoud is offline
Hi!
Just checked the website of Hi-Spec Brakes:
http://www.hispecbrake.co.uk/calipers/sva_spot.htm
Greets,Arnoud Hendriks
pre-'55 oval:stuffed in a barn
1972 1302S(Cali Type4 EFI)
1973 1303S(soon with Oettinger TSV2000)
Old June 11th 2009, 15:54
Originally Posted by Arnoud View Post
Hi!
Not saying it is, but it seems to be just as crappy as the Wilwood spot-caliper
http://info.wilwood.com/CaliperSubCa...Spot%20Caliper
The new combined handbrake calipers from Hi-Spec could be an option though
