Old May 16th 2009, 11:54
bushoarder bushoarder is offline
hydraulic T4
I'm planning a mild T4 1700 W code engine, wondering if the hydraulic cam, lifters etc would fit OK?
Also, since I have lots of bits of D and L jetronic, would a turbo fit either of the systems? L is air sensed and D is pressure, was wondering if the ECU would need a re-map [or another ECU] or the inputs from the air or pressure sensor would enable use. [Other bits upgraded to suit]
