Old July 9th 2009, 15:26
RuleO9 RuleO9 is offline
My bug with 2.4 type 4
Hallo my name is Roel, i'm from Belguim and this is my bug
The start of my project 2 years and 3 months ago..
Old July 9th 2009, 15:35
Nice work, rust cleanup is never fun but you're off to a great start!
Old July 9th 2009, 17:23
Thx!
That work was finished 2 summers ago..
The first idea was to drive with my 1600cc..
Not IRS chassis..
Next stop the paintshop..
Sanding for 2 à 3 months..
Prime coat..
Old July 9th 2009, 17:54
The inside was painted black and than i put the car together at my place..
Back to the paintshop for sanding..
And this was the result after total 4 months work..
Then back home somewhere arround new year 2008...
The start up of the engine failed..
Arround juli past year i sold the 1600 and i bought a 2.0 type 4 engine.
But the engine wasn't in a very good chape.. (it wasn't also expensive)
Then i was thinking, i make my dream come true!
Lets make it a 2.4 type 4... (it toke a while.. almost 1 year)
In mean while i rebuild my chassis to IRS
En porsche 944 suspension and brakes..
A tranny of the later model with stronger differentiel..
Then i had a big problem..
The rims i WANTED... were at the back to wide..
Old July 9th 2009, 18:13
These are my front brakes, disc from kerscher en calliper from porsche boxster
Sway bar from eibach and lowered spindels
The fit the rear rims i had to change the wider porsche 944 changed with the originele and changed the brakes with a set of kerscher..
So this was the view of the last few months..
Also front koni shocks..
And then offcourse the engine pictures..
Drilled at 104.. that's good for 2411cc
316°
914 cilinder heads..
With valves 48 and 40mm
Lightered en polised
BAS exhaust
44 webers with K&N airtake
Old July 9th 2009, 18:24
Than the build of the engine..
123 ignition..
Ready to go to the dyno..
That's were the engine still is, it's over there for a month..
He starts on my engine 21 juli..
This is the look with the rims under my bug (on bricks)
Also put more gages from autometer..
That's my project!
I hope to drive in 4 weeks?
I'll let you know..
Grtz Roel
Old July 9th 2009, 19:56
Humble's Avatar
Humble Humble is offline
Looks good so far! That's a ton of work and it looks like you're very close, keep us updated!
Old July 9th 2009, 20:04
Nice looking project. Lots of nice bits. Keep us updated.
Old July 9th 2009, 21:21
Looking great so far!
Old July 9th 2009, 22:42
Scotts73SB's Avatar
Great build!! Its a shame those connecting rods are hidden in the motor!
Thanks for all the pics! Cant wait to see it done.
Old July 10th 2009, 05:13
Great build; it should be a good autobahnstormer!
(can I ask why you have a MPH speedo in a Belgian car? Also, what have you done about the emergency/parking brake?)
Old July 10th 2009, 06:14
Jim's Avatar
Jim Jim is offline
Very good work!!! Keep us update...
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old July 10th 2009, 06:28
About the MPH.. it was the only one in the shop, and the owner didn't want to order an other 1.. because this one won't get sold.. The red bug frame is from mexico..
And my friends have american cars cars with mph tacho's..
I think it's cool..
About the handbrake, it's hydrolique (on oil)
It's easy to connect ( i did it because it was easyer to connect with the porsche brakes..
Now with the kerscher rear brake kit, i could use the normaal emergency brake, but i already had the hydrolique handbrake..
Today is the front end ready (adaptors were build for the boxster callipers)
Grtz Roel
Old July 10th 2009, 07:22
Hi Grtz,
Thank you for the explanation about the speedo. I guess its the same as the kph speedo I have in my Mercedes. Isn't it supposed to read in kph (as well as MPH) in Begium?
I also have a hydraulic handbrake on the rear of the Beetle that powers the main Porsche 928S4 calipers. But I thought it was a requirement Europewide to have a mechanical hand brake as the emergency/parking brake? My hydraulic handbrake uses the normal handbrake lever to operate the cylinder in a similar fashion to yours but it also still has the cables attached to operate the 944 handbrake shoes. I expect that the mechanical part won't do much on mine as the hydraulic circuit will lock up before the mechanical part does when I get around to filling the system with fluid, so the mech system is a bit redundant. It at least complies with the regulations.
Old July 10th 2009, 15:38
Normaly it's kph, but it doesn't matter.. because, the same reason as the handbrake..
You have 2 choises in Belgium..
1.. you go each year to the controle and LET YOUR CAR IN THE ORIGINELE WAY..
That means, no brakes no engine like we do...
Or 2..
You go 1 time to the controle and than is your car "oldtimer"
And than you only can drive to meetings..
And you can make a testdrive 1 time in the week..
It's a shame up here!!
And my bug is an oldtimer and i can do "any thing a want" because i don't have to go the controle every year..
But if the cops see my brakes and my engine..??
I don't know what will heppen, i think i hear it from the judge!!
