Old October 7th 2009, 10:12
fast Ed's Avatar
fast Ed fast Ed is offline
John's Bug Shop swap meet this Saturday?
Anyone heading out to John's in Welland on Saturday? I know that Lanner plans to head down early, anyone else?
cheers
Ed N.
67 Beetle Sedan
95 Taurus SHO
89 Mustang GT
Old October 7th 2009, 14:25
chug_A_bug's Avatar
I'll Be Sitting on a Beach watching bikini girls... in Cancun So I'm a no go, Have fun boys
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old October 7th 2009, 17:58
CLKWRK's Avatar
CLKWRK CLKWRK is offline
right on, i forgot about it
Ill go
GL ghia restoration:
Old October 7th 2009, 19:11
TunedPerfection's Avatar
TunedPerfection TunedPerfection is offline
I'll be there, but likely not until about 10am. Need to bring some carb jets down for Clyde. See you guys there.
Old October 8th 2009, 10:01
I'll be heading up ... got some T4 stuff for sale as well as some turbo / efi stuff, including my megasquirt brain.
I need a set of aluminum T4 carb intake manifolds .... idf or dellorto, does not matter.
See you guys there.
Old October 8th 2009, 10:48
vdubzack's Avatar
vdubzack vdubzack is offline
I wish I had known about this place. Was up there for the Carabana this year. I think? Things kind of fuzy with mix of rum punch and Molson
Old October 8th 2009, 13:22
petevw's Avatar
petevw petevw is offline
I'll be heading down.
In the TDI with stuff to sell OR cruise the aircooled and hope to not spend any cash.
Who's planning to drive an aircooled to this? Meeting spot?
'72 super
'65 bus
'52 split
Old October 8th 2009, 15:15
fast Ed's Avatar
If I get my lazy ass out of bed early enough, I was going to meet Lanner at his place at 7:00 am ... will be driving the 67 if the weather is as forecasted.
cheers
Ed N.
Old October 8th 2009, 18:08
petevw's Avatar
Quick breakdown of what i may bring:
Aircooled T1:
4spd close ratio fully built(Keven Shull) race trans/solid mounts/Ferrari Shell Helix syn oil
Pauter ALU/Chromo 5.7 chevy journal rods
94mm Cima cylinders x4
84mm 4340 Bugpack chevy journal crank
12lbs flywheel
1700lbs Kep PP
4-puck unsprung disk
magnum straight cut gears
Power Tuning Parts fiberglass 911 fanshroud for VW T1
3-bolt nosecose
S&S merged ceramic header with magnaflow muffler
Bugpack 2inch merged stepped ceramic coated header with O2 bung and 40 series flowmaster
single center mounted Weber carb 45? with manifold
stock intake manifold
stock PP
dual carb linkage
tig'd/balanced/coated fan
15x6 late fuchs x4
15x6 polished early "deep6" repro fuchs x2
H4 bi-xenon HID kit
MK4 2.0L/TDI
TDI 5spd trans with VR6-1.8T drive flanges/200K/lubro oil
2.0L/TDI complete brake setup with spindles/axle
cream headliner/trim/visors/grabhandles/interior lights/pillars/hatch/sunroof shade
new 2.0L/TDI front rotors
steering wheel with airbag
golf tailights
bumper side markers
shift knob/boot
speedo/tach cluster with login codes
wiper stalk
wiper arms/blades
headlight switch with daytime running disabled
15" 5x100 OEM Avus wheels/Michelin's 50%
15" 5x100 OEM steelies with hubcaps/Gislaved Snow tires 85%
15" OEM hubcaps
Added: Electromotive TEC2 ECU for standalone EFI and ignition. Total Engine Control. TEC2 EPROM upgraded.
http://www.directignition.com/pdf_files/tec99.pdf
Let me know as i don' think all this stuff can be jammed in my Golf.......
'72 super
'65 bus
'52 split
Old October 8th 2009, 21:17
Glock's Avatar
Glock Glock is offline
Dammit! I have to work on Saturday.......
74 super,02 WRX,89Cabby and an old beater golf
Old October 9th 2009, 10:22
CLKWRK's Avatar
hey Pete,
I am interested in the T1 tranny, H4 bi-xenon HID kit, dual carb linkage, and
tig'd/balanced/coated fan, bring that stuff if you can
Old October 9th 2009, 10:47
fast Ed's Avatar
If Bryan doesn't take the dual carb linkage, I'd like to have a look at it. Just bought a carb kit off the Samba that is missing the linkage.
cheers
Ed N.
Old October 9th 2009, 11:42
petevw's Avatar
^^^Sweet, i'll bring them.
Bryan, i was planning on bringing the aircooled, so i'll send you the details on the trans. If i need to bring it, the TDI will be making the trip.
'72 super
'65 bus
'52 split
Old October 10th 2009, 20:48
petevw's Avatar
Was a chilly cruise out to the swap, but fun.
Nice seeing some of the BAG crew again.
'72 super
'65 bus
'52 split
