Old December 17th 2009, 11:32
Zigi's Avatar
Zigi Zigi is offline
Zigi's 1303
Hello fans, I am form Czech Republic (Europe) and I want to transfer little bit my 73" 1303 into German Look.
here is my car: http://zigis.wz.cz/foto/Brouk/IMG_2336.jpg
I want to use 17" Porsche CUP wheels, CUP 2 or 3, what I will buy better.
I dont know in Europe a lot of producers of good suspension parts, that I find this one: http://store.airkewld.com/e-shop-onl...ering-kit.html
- what do you think about this one? It is good option? Do you have any other option in maximum of this price???
- do you think I can use standard fenders, or there is no way how to mount 17" Porsche wheels (7J front, 8,5J rear) under stock fenders???
Thank you very much for help and any suggestions. During January I want to order all parts, to handle it before spring.
Old December 17th 2009, 16:37
Looks like the front struts are Topline Maxx Struts. You might want to look at Topline's site.
http://www.toplineparts.com/
Old December 18th 2009, 04:44
Zigi's Avatar
Thanks for the link!
any other ideas about my questions? In Czech is problem to reach any relevant informations I really appreciate your help. I dont want to order or find out anything bad, when it was solved long time ago before I want to do it
My dream result is my cream bug, on "antracit" 17" Porsche CUP wheels. Engine is now rebuilding, to be little bit stronger And I have no idea about fenders.....and it is hard to get them into Czech, in good condition, and for some reasonable price + postage.
thanks for your help ! and I will post progress pictures
73' 1303 CREAM
Old December 18th 2009, 06:45
Many people have used Porsche 17x7 wheels under stock fenders with the Topline MaxxStrut on the front and a bit of clearancing on the bump stop cup at the rear. Some have had to flip the forward bolt on the spring plate/trailing are joint also.
Old December 18th 2009, 07:43
Zigi's Avatar
That sounds perfect!
Problem is,that most common 17 CUP wheels have ET front 50 and rear 55....do you think this still can be under stock fenders?
And what about brakes,my plan was only to exchange my drums for drums with 5x130 patterns. That was first. And cheap solution, but I know now enough. Do you think when I use these drums, it will fits still?
Do you have any brake "sets" which you can recomand to me, which can be easily replaced for original drums on my car? I think this will be pretty expensive thing for me
Thank you very much!
73' 1303 CREAM
Old December 18th 2009, 14:25
chug_A_bug's Avatar
you can atleast put a type3 disc with a 5X130 and Keep the Stock Drums on the back...
http://www.cip1.ca/ProductDetails.as...C%2DC10%2D4123
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old December 18th 2009, 15:46
Zigi's Avatar
Nice, thank you, I found this kit on www.toplineparts.com written above. Better to transport it from USA than Canada, thank you!
But this kit is 4x130 as Super Beetle??? Or 5x130?
Or rear, I have to change it for drums with 5x130 as well, now I have 4x130, or do you think, there will be a spacer for change from 4x130 to 5x130 ???? Or not a space for spacer under 17" CUP wheel ??
73' 1303 CREAM
Old December 18th 2009, 16:14
chug_A_bug's Avatar
your best bet is to get blank rotor and Drums and drill them to 5x130.
That Site I posted, you can buy them already done...
74 Std. GL
08 Vw rabbit
18 WR250R
Old December 18th 2009, 17:20
Zigi's Avatar
this is my goal. But I still dont know if 8J or 8,5J will fit under stock rear fenders And the brakes wont be big like this Porsche ones. The rest will be I hope like this Looking forward to collect all the parts.
73' 1303 CREAM
Old January 18th 2010, 06:18
Zigi's Avatar
Some progress.
Yesterday I bought on eBay CUP 3 wheels
7J and 8,5J....I hope they will fit under stock fenders, what do you mind?
The suspension will be complete kit from Airkewld ( Topline front)
+ I found front 944 brakes. Only there I have no idea what will be neccesary for installing them on me 1303 with drums
If you have any ideas, I will be glad.
Enjoy new year 2010, back with Germanlook forum
73' 1303 CREAM
Old January 18th 2010, 06:22
Zigi's Avatar
Maybe can some admin put my topic into projects? It is now not only a question of suspension,and I was new here Sorry admins!
Thanks a lot,Lukas
73' 1303 CREAM
Old October 19th 2010, 14:35
Zigi's Avatar
Very first touch. Rear has to go lower, but that will be adjusted according how low we should go with the front.
Finally new look of 944 Turbo seats.
Porsche brakes all around finally.
The season is over, but I want to be ready for next season from the begining :-)
73' 1303 CREAM
Old October 20th 2010, 08:31
Did you source your front coilovers? Not wishing to upset anybody but I would stick with a European supplier for the suspension parts as they will know local (European) conditions. Traditionally, main stream manufacturers have different settings for different markets. GL is about performance IMO so I would look to Bilstein, Koni, CSP, Spax, Avo etc for the suspension package.
It is likely that the front end will be stiffer and because you are lowering the rear that needs to be stiffer to. Change the rear torsion bars and/or add coilovers. If you have stiff coilovers then add a 5 bar Kafer Cup brace to the rear and a strut brace to the front.
Performance kit will not work properly without the correct control so, fit at least poly bushes all round.
I wasn't aware there was a season????? Its just as much fun playing in snow as on dry tarmac.
Old October 20th 2010, 10:46
Zigi's Avatar
The front will be Maxx Strut:
Engine is already in. But nothing killing, just 1775 with a few adjustements.
This will be a first version, to find out all problems with Porsche brakes, standard fenders + Porsche wheels, etc. Testing Begining of GL, not a racing special at all. So after it will be complete, I wil start to test the chassis, car.
73' 1303 CREAM
Old January 7th 2011, 14:23
Zigi's Avatar
Some news :-) Now we can start with finish design works. Dechroming, carbon, black color, etc. Another front tire, interior finish, still a lot to do.
73' 1303 CREAM
