Old January 20th 2010, 07:25
Obiwan Obiwan is offline
Obiwan German Look Project (1302 FR)
Hello masters of the GL,
I'm Peter, alias Obiwan, from south of France. I'm 35 yeras old and I'm working as space engineer for the European version of the GPS called Galileo.
My father in law offered me last year its 1971 1302 SB. After 200000 km and no major problems this first hand super beetle will be the starting point of my GL project.
My project is ambitious and it will takes time & money to achieve it but I'm very motivated so... let's start the description.
Engine : The heart of the beast
Case : Porsche 914 2.0 GB code : Inspected ok
Pistons/Cylinders : 103mm QSC alu nikasil cylinders / Specific JE Pistons
Crankcase : DMS 71mm CW with heat treatment
Camshaft : Schleischer 324° (106°)
Lifters : Remmele T4 lightweighted
Heads: VW CJ 2.0 heads prepared by BAS (44x38 vavles, 3 angles valve seats, intake ports rebuild...)
Rockers arms : Porsche 1.7 with 911 elephant foot adjusters
Carbs : 2x45 DRLA on shorts and aligned pipes
Cooling : Porsche 911 Fan
Brakes :
911 (996) calipers front & rear
996 front brake disc
Rear brake disc : 944 S2 or 996
Chassis:
Coilovers Front & Rear
Front SB disc spindles (2 points)
Removal of the rear torsion bar for uniball link
Upgraded front anti-roll bar
Upper front strut barce
Rear 944 anti-roll bar
Eyeballengenering rear strut brace
944 S2 aluminium rear trailing arms
Steering : rack & pinion device is under study
Wheels :
Porsche CUP1 17"
Sorry for my bad English.
Have a nice day guys,
Obiwan
Old January 20th 2010, 14:52
Welcome, glad your here!
Pics are always enjoyed, even if it's just parts in boxes, it gets the juices flowing, so post some up if you can.
Great sounding project, I love it when engineering types get started on projects, the results are always surprising.
Old January 20th 2010, 19:21
hotsauce's Avatar
hotsauce hotsauce is offline
X2, pics are a must!!!!!
just another square saltine.
www.garagejunkieapparel.com
Old January 20th 2010, 22:06
Welcome, Look forward to your pix and reports.
Old January 20th 2010, 22:17
Welcome to the GL world!
Like everyone else said....
...man I've been wanting to use that!
Old January 20th 2010, 22:27
hotsauce's Avatar
hee hee, how bout this.....
Old January 21st 2010, 13:53
Cool project!
Let us know how the QSC nikasils run on your 2.4 T4 engine!!
Does it run yet??
Tnx.
Old January 25th 2010, 04:55
Cool project!
Does it run yet??
Tnx.
Not yet, be sure that i'll put a video of the engine start....when it will be finished
Thanks you all of you for your welcome. I'll put some pics soon
Old January 25th 2010, 06:03
TSAF's Avatar
TSAF TSAF is offline
Welcome, nice project. Mine started originally as a 2.4 as well. I have one suggestion-friendly advice. Go for a 332° Schleicher. Major difference in the power output.
VW 1303s 1975 (German Look)
VW 1300 1964 (Rally Car)
LAND ROVER DEFENDER 90 V8
BMW E30 318i CONVERTIBLE 1992
Old January 25th 2010, 12:18
Hello TASF,
I've lost my hairs on camshaft selection ! After many discussions with guys that have a lot of experience in the Beetle Cup it seems that :
First it's difficult to compare both camshaft as they are much different in terms of duration at high lift. The 324° (106° LC) is comparison with the the 332° (103° LC) will allow more power at lower rpm due to max torque obtained earlier without clear loss of power at high rpm. The utilisation range is wider with the 324°.
Old January 26th 2010, 04:09
TSAF's Avatar
While I was talking to one of the experts I bought my heads from he suggested the camshaft I told you about. Anyway if you are satisfied with the 324 then there is no problem.
