Old January 20th 2010, 14:47
wrxJim's Avatar
wrxJim wrxJim is offline
Parts clearout 944, Subaru and more
I have decided to sell up a massive amount of the parts i have collected for various projects over the years as i need some funds to get started on my split project, have a read see if there is anything of interest.
Subaru Engine EJ20 Turbo complete unit removed from accident damaged car bought running. Includes clutch, flywheel, altenator,intercooler, loom, matched prodrive ecu set £700
Subaru engine long block EJ20 Turbo removed from a fire damaged car, good spec copper head gaskets installed, comes with Lightened flywheel, clutch, IHI VF TURBO, Forge wastegate (as new), Bailey dump valve, HKS induction kit, Autobahn 88 silicone intake hose, lightweight pulleys (new), Tubular exhaust manifold. £500
Porsche 944 S2 alloy rear a-arms with hubs and discs, d-shafts, roll bar, spring plates and fixings. £250
Porsche 944 N/A hubs,brgs,as new discs,calipers and as new pads Ideal for a splitty conversion £150
Porsche 944 N/A front spindles 2 pairs with drillings for speedo cable £20 pair
Porsche 944 N/A Front brake calipers gwo £40
Porsche 944 N/A Rear A-arms (steel) £50
Porsche 944 N/A drive shafts 100mm cv's need new gaiters £40
Long travel balljoints new in packets set of 4 for TYP 1 arms. £45
1303 2 bolt strut lower arms and anti roll bar £50
200mm clutch early type 3 finger pressure plate good friction plate. £20
180mm flywheel clutch assy good condition. £20
SOLEX 31 pict-3 carb £15
SOLEX H 30/31 pict carb £15
SOLEX 31 pict-4 carb £15
Late Bug door seal genuine (new) bought from custom commercial £10
Early Bug door seal genuine (new) bought from custom commercial
£10
More to be added soon when i dig it all out. Thanks for looking
Old January 20th 2010, 17:32
Xellex's Avatar
Xellex Xellex is offline
Originally Posted by wrxJim View Post
1303 steering rack complete with track rods U/J and columb ideal for conversion. £50
Do you have the 2 original mounting brackets for that too? Would you consider shipping it to Romania? I'd like to have one of those lying around. Oh, and do you take paypal by any chance?
Thanks, Alex.
www.vw1303s.com
Old January 22nd 2010, 03:43
wrxJim's Avatar
Thanks, Alex.
Hi the rack is complete with brackets at either end. I will look into a cost for shipping and get back to you.
Cheers, Jim
Old January 22nd 2010, 06:49
Obiwan Obiwan is offline
Hello Jim,
I'm also interested into your complete rack, nevertheless put me in second place as Xellex contact you first for this.
