Old February 10th 2010, 11:03
verbeekb's Avatar
verbeekb verbeekb is offline
NOS Porsche Type 4 Parts
8 - 021101173 Sealing Ring - 2.66 Euro ea.
1 - 021101269A Sealing Ring - 4.34 Euro ea.
4 - 021101341A Sealing Ring - 4.74 Euro ea.
4 - 021101343 Sealing Ring - 5.30 Euro ea.
4 - 021101403A 914 Valve Guide - 18.70 Euro ea.
4 - 021101417A 914 Valve Guide - 19.55 Euro ea.
2 - 021101481 Valve Cover Gasket - 4.34 Euro ea.
2 - 021101487 Valve Cover Clamp - 6.94 Euro ea.
4 - 021105431A Connecting Rod Bush - 7.52 Euro ea.
1 - 021109339 Push Rod Tube Securing Clip - 7.07 Euro ea.
8 - 021109345A Push Rod Tube Sealing Ring - 2.66 Euro ea.
10 - 021109349B Push Rod Tube Sealing Ring - 3.53 Euro ea.
8 - 021109427 Bearing Shell - 8.83 Euro ea.
1 - 021115133 Sealing Ring - 1.51 Euro ea.
1 - 021115175 Oil Strainer - 15.30 Euro ea.
1 - 021115353A Intermediate Flange - 61.90 Euro ea.
1 - 021115359A Gasket - 8.83 Euro ea.
1 - 021115487 Gasket - 2.79 Euro ea.
2 - 021119569 Rubber Grommet - 2.61 Euro ea.
12 - 021119569A Rubber Grommet - 2.61 Euro ea.
2 - 021127311A Gasket - 1.69 Euro ea.
3 - 021256251A Sealing Ring - 4.34 Euro ea.
1 - 021919081B Oil Pressure Switch - 8.54 Euro ea.
4 - 021101107 Vibration Damper - 0.88 Euro ea.
3 - 021107371 Oil Scraper Ring - 9.46 Euro ea.
3 - 021119553 Drain Bush - 2.14 Euro ea.
7 - 021101269 Gasket - 0.48 Euro ea.
2 - 021101471 Valve Cover - 18.60 Euro ea.
8 - 021109335C Push Rod Tube - 8.76 Euro ea.
4 - 021109407A Rocker Shaft - 44.00 Euro ea.
20 - 021109435 Washer - 0.95 Euro ea.
2 - 021198031B Set Of Seals - 4.80 Euro ea.
8 - 022119356A Air Deflector - 16.80 Euro ea.
1 - 022256206A Flap Control Box - 110.00 Euro ea.
3 - 022906102 Protection Cap - 9.48 Euro ea.
1 - 022115309 Cover - 15.75 Euro ea.
8 - 022109309 Hydraulic Lifter - 24.05 Euro ea. (NOTE: Volkswagen part)
4 - 039101403 914 Valve Guide - 16.35 Euro ea.
4 - 039101421 914 Valve Guide - 16.85 Euro ea.
16 - 039105701 Bearing Shell - 9.34 Euro ea.
8 - 039256297 Mid Grip Exhaust Nut - 8.67 Euro ea.
1 - 039133073 Gasket - 2.84 Euro ea.
1 - 039919268 Sender - 24.15 Euro ea.
13 - 411501149A 100mm CV joint Boot w. metal flange - 22.00/set of 4 (non-genuine part)
All brand new in genuine Porsche packaging. Above are export prices, within Europe I am required to charge our 21% VAT (unless you have a valid VAT number), if interested in more, all or relatively expensive parts I will apply a discount. Note that Porsche often has Type 4 parts available that are no longer available through VW. When Porsche and VW share the same part/part number, Porsche is usually cheaper priced than VW. Open to trades. Will ship world wide.
1970 917 Poser
1972 Brunette
2004 VW Sedan
2005 VW LT 35 2.5 TDI
www.karrera.net
