Old February 17th 2010, 20:42
hotsauce's Avatar
hotsauce hotsauce is offline
Difference between heads
Did a little searching, but didnt come up with the answers i was looking for.
i just came into a 1.7 type 4 engine that im going to be putting into my bus and would like to put the Porsche heads on it if possible.
What is the difference between a stock type 4 head and a 914 head? Bigger valves and higher compression?
Can the different engine size variations be swapped? IE: put 2.0 heads on a 1.7 if i upsize the pistons/cylinders and bore the heads accordingly.
Is there a "slip in" P/L set that would work, so i dont have to completely dis-assemble the engine?
just another square saltine.
www.garagejunkieapparel.com
Old February 18th 2010, 06:32
Bogara_ZO's Avatar
hope it helps. technically you can do that, but using a 2.0L porsche head on a bone stock 1.7 doesn't make any sense for me.
http://www.tunacan.net/t4/reference/cylhead.htm
Old February 18th 2010, 19:34
hotsauce's Avatar
hmmm, for some reason all i get from the tunacan website is a blank page. i got that for the last two days as well in my searching.
The engine i have isnt technically "stock". According to the guy i got it from it "has a cam but cant remember the specs on everything"
Old February 19th 2010, 04:13
Bogara_ZO's Avatar
for me that link works.. try to open it somehow (maybe from an other PC), and read all the necessary infos, I think that's a very useful homepage. Knowing the cam you are running it's a MUST
Old March 1st 2010, 11:29
hotsauce's Avatar
Holy crap, the linky works now!!!!
Thanks for the info.
