Convert2.1 DJ engine to aircooled
I was thinking i could machine the case to fit aircooled type 1 Barrels .The bolt spacing appears the same ,someone has done this before surely?Is the case ally or magnesium?I havnt got an engine yet but this could be a good project .
Thanks Mike
The wisest mind has something yet to learn |
Thanks,shame about the head studs and having to machine so many fins off the barrel.i take it the case is ally like a type 4?.
He has been doing this for a Loong time... http://rockyjennings.com/
Click on H20 to air in links on left side of page.
I really wanted to give this a go but those eccentric head studs are putting me off , also going back to 8mm studs .When i saw the eccentric head studs i wondered if the head could be slotted but i suppose they already tried that?? .
The plus for me would be an ally case and not to use a type 1 case as that was one reason i built a type 4 .No mention of tinware .If there is 12mm of jacket left on the case ,type 1 tins aint gonna fit so i am back in the realms of making tinware. I'll do some more searching for completed engines . Thanks
Just been reading the oxyboxer forum.looks like a whole new world and a lot of machining!Still not sure about them really .I may just stick to type 4s.
Or you can get -if you have to afford- the heads from gwd or JPM ready drilled for the wbx stud spacing and you're done
jpmotorsport.se gwd-weiser.de Friendly Dimitrios |
Thanks ,the whole challenge for me is building something using the skills i have and a bit of creative imagination.Besides that my wife wont let me buy the nice ready made stuff
A friend of mine who is a machinist made it really simple to work out the head stud issue. He fitted a oversize solid insert in the factory head stud hole and then re-drilled it suit the heads he was using. You could always keep the water cooling, I did it on my 1302 and it was pretty successful.. Steve
