Old February 18th 2010, 17:12
bamberjim's Avatar
bamberjim bamberjim is offline
OMP Seat frame
i have purchased a OMP seat for my cabriolet.. but omp don't list a subframe for the beetle.. am i right in thinking a mk1 golf is the same? mines a 76 3 point runner type cheers jim
Old February 18th 2010, 22:50
Bug@5speed(US)'s Avatar
Bamberjim,
Corbeau, makes a seat rail for the bug, may want to check and see if it will work for you..
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old February 19th 2010, 08:24
bamberjim's Avatar
Thanks Alex, have been told mk1 golf is different will have a look ath the cobra.. or CSP do one but its for recaros..
bamberjim's Avatar
Thanks Alex, have been told mk1 golf is different will have a look at the cobra.. or CSP do one but its for recaros..
Old February 19th 2010, 09:19
Hi Bamberjim,
If I can give my 3 penny worth. The bug 3 point fitting is IMO dreadful in that it is quite unstable and not a base suitable for any sports seat. On our '03 Super we created a subframe onto which standard universal type runners fit. The whole thing is quite rigid and gives the confidence that the seat is not going to break away as the 3 point fixing does.
Old February 19th 2010, 18:44
bamberjim's Avatar
thanks clive, any pics?
Old February 20th 2010, 00:34
Humble's Avatar
Humble Humble is offline
I'm with Clive on this, the later 3 point seat mounts suck and I've been fighting with them for a while. Corbeau does have a seat bracket and I'm using it in the race bug but the seat position is pretty high and needs to be about 3" lower (I'm 6' btw). I would highly recommend cutting out the 3rd mount and fabricating one or finding a universal mount that works.
Old February 20th 2010, 10:45
@Humble..
On my car I swapped to earlier SB pans so I can run the pre 74 3 point setup.. Any idea how the seating position is on these..
Alex Olaverri
Tele: 973 204-5463
Old February 20th 2010, 14:49
Humble's Avatar
I used the corbeau seat frames in my old 72 super race chassis and while they were still a little too tall for my tastes they weren't nearly as bad as the 3 point style. I think the best way is to fabricate your own mounts that way you can get the perfect seating position. You might be able to use a universal seat mount and reinforce the pan or weld tabs to the heater channel and center tunnel.
Actually I still have a set for a 71-72 super that you might be able to modify to suit your needs if you want them.
Old February 20th 2010, 19:47
Humble,
Send me the info via PM, and some pics..
Don't wan't to clog this thread.. Interested
Alex Olaverri
Tele: 973 204-5463
