Old April 1st 2010, 15:08
Plipton Plipton is offline
IRS into 54 oval.... Track width problems
Hi All,
First post on here so hello to everyone
I am converting the rear of my oval to IRS but have found the rear wheels stick out too far so I need to narrow the trailing arms or buy some custom ones so that they tuck in under the arches.
So my questions for the forum....
  • What is the width of a stock early swing axle rear end ? (I don't have the original gearbox or axles etc to measure).
  • What is the width of a stock IRS rear?
Measurements (if possible) in mm and from drum to drum (wheel mounting face) please.
Nearest I have found on here is this post which gives me everything else I need to know.
Plipton
Old April 1st 2010, 19:02
If you use a 6 inch wide wheel with amore inset (ie and 52mm vs a 23mm inset) would that clear things up?
Old April 2nd 2010, 09:03
Yeah it would........ but (at the risk of horrifying everyone on here) I want to stick to wide 5 stud pattern - I have a set of CSP disks which cost the fat end of £2000 and (horror of horrors) a set of original Empis so I can't really afford to replace them for quite a while.
Unfortunately all the wide 5s I've seen have next to no offset so I need to narrow the diagonal arms but it's a bit hit and miss without knowing the original measurements.
Cheers
Plipton
Old April 2nd 2010, 10:07
I had Type 3, 4 stud rear brakes on a 1303, it was 1405 mm drum face to drum face.
I think the Type 3 brakes might add a few mm.
Old April 3rd 2010, 05:21
Thanks Steve,
I have a pair of Type 3 drums to use as a comparison so should be able to use that as a starting point
Anyone out there got the same measurement for an early Type 1??
Ta
Rick
Old April 3rd 2010, 08:09
You could have Boulton Wheels make up a set of wheels. They take wide 5 centers and weld them to a GM steel wheel hoop and can do any offset. So you could do a 15x6 with 55mm inset.
Old April 3rd 2010, 10:54
Boutlon Wheels sounds like a possible plan. Do they have a website? I can't find them on Google.
Old April 3rd 2010, 20:15
I can find you some info.
Old April 4th 2010, 15:35
Old April 4th 2010, 20:24
Here is a link to the place I ws thinking of. It is Stockton Wheel not Boulton.
http://www.stocktonwheel.com/
Old April 5th 2010, 08:52
Thanks for that. I'll give them a call and see what they can do. Looks like they may be able to make 15s into 16s which would look a whole lot better
Meanwhile, if anyone could measure their early SA bug rear end it would be much appreciated.
Old April 6th 2010, 13:54
While you are waiting for your answer, I'm curious ... besides wanting to maintain the wide-five pattern, was putting an oval on an IRS chassis otherwise difficult?
(2004-2008): 1971 1302 w/2056
Old April 6th 2010, 15:02
No, not at all. Only the rear body mounts had to be lifted to accommodate the later shock mounts. I used a '69 semi-auto IRS chassis with a clutch tube welded into the tunnel.
However, that was the '56. Many years after being "restored" I found that it had been done badly with non-original parts. That's not to say it is beyond use but that the heater channels and valances are wrong for the year. I was tempted to get it all redone and then at the VolksWorld show last year I was offered a near-perfect 54 shell and chassis for 1/2 the cost of the repairs so I grabbed it.
The chassis I am now using is the '54 but with IRS diagonal arm mounts welded into the rear forks.
Here's some pics of the 56 on the 69 chassis....
Edited to say - oops just noticed the first pic is of the SA chassis
Old April 6th 2010, 15:12
The trouble is the offset on wide 5s is much less than the later 4 stud wheels so they don't fit under the arches without some work. I like the arches to look full so I need to get this spot on!
Tags
irs, swing, track, wheel, width
