Old April 8th 2010, 02:25
seangfy seangfy is offline
help with subie ecu
im in the middle of going subaru in my 73 super but ive came acrosse a delema im not sure what ecu to use i have a ej20 motor that was a twin turbo japanese lagacy engine but im converting it to single turbo not sure what ecu to use was planing on using a megasquirt system but thares a lot of tuning involved in that not sure if i can figure out all the software or to use a stock wrx ecu from a local wrecking yard but i dont know if it will work due to my engine being a japanese motor any help or info on this subject would be awsome thanks in advance
Old April 8th 2010, 04:47
You may be better off asking this question on AussieVeedubbers or vwkd.co.uk
Old April 8th 2010, 12:13
Humble's Avatar
Humble Humble is offline
I'm not sure where you're at but I ran into the same problem. Unfortunately you can't use the wrx ecu because the ecu plugs are different. I'm not sure what legacy ecus there are to choose from or if they will work with the single turbo conversion. Your best bet might be a plug and play setup from outfront motorsports or the like. It's expensive but it's ready to go out of the box.
Old April 8th 2010, 13:47
Bug@5speed(US)'s Avatar
Sean,
Go over to NASIOC.. and check the Engine Tuning section, this has been addressed there plenty of times with all the swaps occuring..
IF the Wrx ecu is usuable, you can leverage some open source software, to do the road tune yourself.. I spoke to a guy 2-3 years ago, and he had done it on a Saab 92x.. and said it was not to difficult to map it yourself.. or find someone with a similiar map to leverage..
Either way, NASIOC may be a good place to start.. Just watch out, there are a bunch of folks who lack maturity, and can be a PITA to deal with..
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old April 8th 2010, 16:19
I will look into the subaru forums for sure megasqurirt still might be the way I go thanks for the replys guys
Old April 8th 2010, 22:55
johnny p johnny p is offline
you can use the twin turbo ecu to run the motor with 1 turbo . people have done this with good results.
Tags
ecu, subaru
