Old December 27th 2002, 09:41
Martice's Avatar
Martice Martice is offline
porsche 944
Hi,
I just found a '87 944 for parts
My bug is '71 1302(superbeetle)
What can I use on my bug from this porsche model?I am only thinking about the seats right now .I do not know much about the brake conversion but what else besides the 944 brake parts will I need for this conversion, other parts than the ones that can be manufactured/machined?
I am afraid that the brake conversoin will be to expensive at the end.
I can find easy 1303 suspension parts here.So if I decide to use 944 it will be on 1303 suspension.The machining isn't a problem either.
And what else can I use? Tachometer?speedo? other gauges? any other suspension parts?
thanks for any info on this!
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old December 27th 2002, 12:21
Pillow's Avatar
Pillow Pillow is offline
Sweeet!
Here is what I have found good to use:
Front brakes and spindles (for a 1303). Take the whole assembly.
Rear axle... Just yank the whole thing as you need most of it anyway. Easy to drop with three bolts per side then just cut any wires/lines that snag at the end.
This gets you:
Rear brakes complete
Control arms
Torsion bars
Also you could grab the steering wheel if that is something you like.
Seats.
The rest sell for parts.
Hope this kinda helps.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old December 27th 2002, 12:46
Martice's Avatar
Thanks Adrian!
Here is something I am afraid of, If I have all the parts from the 944 and the 1303 suspension, what else do I need?
If I remember well,you have an early 944 brake setup on your bus right?How much did you spend on the other parts(adapters, bearings, etc)
and if you can estimate a cost for the beetle conversion(again, not counting the 944 parts, just the other parts that I might need)
I just don't want to end up with something that I can't afford right now, even if I get the porsche parts at a reasonable price...You know what I am talking about.
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old December 27th 2002, 15:04
Pillow's Avatar
See the suspension forum for my rundown of the bus costs.
From what I understand Kercher makes the 1303 ball joint adapters and you are rolling after that! The 1303 has to be the easiest car made to make the conversion from what I can tell.
Also if your bearings are good just reuse them, no worries and saves some $.
Oops forgot the e-brake cable adaptors from CSP? which are cheap and easy as well.
Do it! do it! do it!
Your only holdback might be the wheels, but if you get a whole 94 that is taken care of as well.
Good Luck,
Adrian Pillow
Old December 28th 2002, 04:57
Martice's Avatar
Thanks Adrian.
I'll see what prices I can negociate for the brake parts.I'll not buy the whole car as there is no more room .I have three beetles around my house right now...
Later,
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 2nd 2003, 14:00
Philippe Philippe is offline
Gauges! Get the Gauges!!!
Old January 2nd 2003, 15:37
Farmer Farmer is offline
AND THE REAR SWAY BAR !!!!!!!!!:silly:
Old January 5th 2003, 08:03
Martice's Avatar
Hey,
thanks!
I am just wondering if the speedometer would work?
Later,
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 6th 2003, 20:34
i heart vw i heart vw is offline
i have 924 speed o in my 62 and works fine, but a little off but not much...
saddly my 74 super has to go ...
Old January 7th 2003, 14:41
Martice's Avatar
Hi,
I just checked the 944...the front rotors seem pretty worn out, + he is asking $450 for the brakes which is a little too much for my poket right now.So here goes my chance
I've had some 40mm adapters for some zender wheels to stock vw pattern anyway so I'll be able to use the wheels ...
Farmer,
what I would like to ask, can I use the sway-bars on my stock suspension?
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 8th 2003, 01:32
Pillow's Avatar
From my experiences all the early brake setups I have gotten are worn out for the rotors and pads.
Most of the late 944 stuff is good to go, but the early stuff I just plan to pay for new rotors and caliper rebuilds all the way around... It is amazing how much schniz builds up in the calipers!
$450 seems high to me anyway.
Take Care,
Adrian
Adrian Pillow
Old January 9th 2003, 01:44
chigger chigger is offline
The rotors for the early 944s run about $50 each at Pelican parts. Turbo rotors about $250 each and then they go up. My buddy who is a professional mechanic I asked about my rotors being out of spec. Minimun spec is .75 inches these were .73 inches. His opinion was that inspite of the massive calipers I have since the car is about 1000lbs lighter in weight there should be no problem and that in fact I will probably never wear them out unless I race alot. I will be monitoring them closely though. They are still heavy. Hope it helps.
Old February 3rd 2003, 05:56
Martice's Avatar
'86 PORSCHE 944 TURBO
Hello again,
I just found another Porsche 944, but this one is the Turbo model...Man those brakes are a beauty!
I know that the turbo conversion is harder to do vs the non turbo conversion.Why?..I do not know...
What's involved?
Will the sipndle fit?will I need adapters or different spindle?
I may get the wheels also.But I really need to know whats involved in this conversion!
THANKS!!
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old February 3rd 2003, 06:11
Tim Tim is offline
Martice,
For the front, if you are installing on the 1302, you don't need the CB spindles but the 944 spindles using the late 1303 control arms with the 17mm balljoints from Kerscher. You need the late 1303 struts but I don't know whether the mounting holes of 944 turbo spindles will fit (early 944 spindles will fit). The whole front brake assemble of the 944 turbo can be retained - 944 wheel bearings, hubs (no need machining and adaptors).
For the rear, I think it is straight forward if you can get as well the 944 turbo control arms, spring plates, maybe the axles and CV joints. I am not sure whether the 944 inner CV joints will fit the beetle output flanges. Maybe you need to change the output flanges.
Tim
Old February 3rd 2003, 06:48
Martice's Avatar
So it works! great! I'll move to 1303 suspension in this case, of course.
Do you have any idea about how much the 17mm Kerscher ball joints could cost?
My problem now would be the cost because i do not want to end up spending a small fortune on this conversion...
If i'll buy i'll buy all the brake and suspension parts needed from the 944 also(including rear control arms sway bar etc)Besides that,will I only need early 944 spindles and krescher ball joints and thats it?
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
