Old July 26th 2010, 05:55
kai4130 kai4130 is offline
915 lubrication quantity
So as per the title I have a 915, I believe it's the all aluminium version and I've fitted it with a Quaiffe ATB differential.
I need to know how much oil I should be putting into it. In litres please, I think it's 2.4 or 2.6.
Here is the numbers:
I've bought 3 litres of Castrol B373 which is apparently a superdooder mineral based oil.
http://www.opieoils.co.uk/p-712-cast...productDetails
Thanks in advance
Old July 26th 2010, 07:20
The info I have says 3 litres, if the trans has just been built they sometimes take a little extra.
Old July 26th 2010, 09:28
Steve,
thanks very much for the info. I can't see the image at the minute (on my phone) But I'll ceck it out later on.
Quaiffe fitted the diff to the box but they didn't take the gear housing apart, they literally just replaced the diff. The whole box and diff has cost me £2k already and I can't justify a rebuild just yet
Old July 26th 2010, 13:52
Righto then so my 915 is out of a 1983 911 sc, good for a reference.
Is that like a Auto data database software your using there then?
Old July 26th 2010, 14:22
From memory I filled my old 915 until it was level with the fill hole on the side just like a VW trans...
Old July 26th 2010, 16:17
Hi Rich,
I see your project is coming along very nicely... I'd better get my skates on our you'll have fully restored bug in the time its taken me to fit my engine
Ok so I googled it and found this:
http://forums.pelicanparts.com/porsc...-quantity.html
I'll just stick my 3 litres in it or until it comes out the hole
Old July 27th 2010, 09:56
Its actually the genuine Porsche parts program called PET, very useful.
Old July 27th 2010, 18:33
Well I got round to filling the box tonight AND...............................
It took just about 3 litres before it came pissing out the side hole
Thanks for all your help guys
