Old December 29th 2002, 18:24
Question 200 pp/disc on a 210 fly
can you use a 200mm pp and disc on a 210mm flywheel? I got a 210 flywheel in a trade and want to go with a KEP 200mm Stage I and some kind of 200mm disc, but need to verify that will work. i know the disc will work, just don't know about the pp.
Old January 12th 2003, 12:31
Tom Alltypes's Avatar
Tom Alltypes Tom Alltypes is offline
I'm running a 200mm Dual friction Berg disc under a stock bus 210mm PP. It works great and doesn't slip, even with my heavy t3 and a 2.55L motor.
Tom Alltypes
Tom's Old VW Home
