Old October 5th 2010, 21:36
onixbonilla's Avatar
onixbonilla onixbonilla is offline
911 gauges
Hi everybody! I am interested on 911 gauges for my 1303 with a Kerscher dash. Will like to know if there is any tutorial to make them work on our cars?
Or maybe you can guide me?
I am naive on this topic!
Thanks!
Old June 7th 2011, 17:35
I did not found to much information on this topic. Anyway I manage to get
a custom set for my VW.
Old June 7th 2011, 18:37
Nice set of gauges. If the tack is made for a 6 cyl. You may have to have it modified for a 4 cyl. North Hollywood Speedometer and Palo Alto Speedometer can do the job. I am sure there are others.
Old June 7th 2011, 20:07
Thanks, these were modified by North Hollywood for my 1303.
Old June 7th 2011, 20:31
Sweet.
Old June 8th 2011, 04:50
Xellex's Avatar
Xellex Xellex is offline
nice set! They will look awesome on your bug for sure! The wiring is pretty easy to do. Right now I also made the speedo work, and the only one not working on my set is the oil tank level. It's nice that you had it converted to a voltmeter.
I wonder what they modify inside the tacho for the 4 cylinder conversion. Mine is still factory sealed and never opened, so I prefer not to mess with it, so I'm working with a friend of mine on a device that would go on the wire between the coil and tacho, and multiply/divide the coil signal pulses by 2/3. I hope it will work.
www.vw1303s.com
Old June 12th 2011, 00:08
NHS does great work. Those gauges are fine examples indeed
(2004-2008): 1971 1302 w/2056
Old June 14th 2011, 16:15
I would say this is one of those few times that the quality of the work is better than expected!
Old August 15th 2013, 13:40
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Did you ever get your dash in?
Old August 16th 2013, 23:19
Hi SuperRSi! Well I finally fell to the "various projects at the same time" trap so I had not been able to install these! By the way I just realized that I have had those for 2 years!
