Old November 8th 2010, 23:50
vdubfund's Avatar
vdubfund vdubfund is offline
964 rear brembo 2 pots
Have been running these on my 64 short axle bug now for a couple three months now. Everything is working great. Also am using a 944 MC except switch the lines. The rear is fed off the 23mm port / and currently the front drums are being fed off the 19mm. Great feel!! I will keep this current configuration even when I install the 944T fronts.
Also am trying out a single shielded rear axle bearing in the rear (SKF) to help reduce any oil leaks that may occur.
2 pot brembo
996 rear discs
924T adapters
Cheers to Lanner for all his help, past and pending.
Old November 9th 2010, 03:53
I have a set on the rear of my sons 1303, they are working well with a stock 19 mm MC
Old November 10th 2010, 08:40
What's the piston size of the 964 two pots? You may have to swap the m/c connections over to suit the 944T front calipers. You will need to assess the hydraulic advantage in both the front and rear lines to ensure that one end is not overbraked.
