Old November 10th 2010, 13:36
Luismj's Avatar
Luismj Luismj is offline
Drive By Wire.
One friend in Brazil (fabigode) develop one double drive by wire for one aircooled 2.0 megasquirted:
Beetle with cruise control!
VIDEO ETB 48mm IN ACTION:
http://www.youtube.com/watch?v=1wRRvqX2Hgo
Very interesting!
Anyone ever seen something similar around the world?? (I try to get more information about it.)
CUP2 17x7x9 Brembo.w.Servo&Master.Cylinder/IRS/CB Dropped Spindle
GTI 2.1 16V Turbo Forged/Sapinho/Fueltech EVO-GL
Old November 10th 2010, 16:03
I was going to use the stock DBW setup on my 1.8t, but in the end I went standalone ECU and cable. With the availability of reconfigureable software available for flashing stock ECUs now, I think I'd go stock if I had to do it again.
Still, there's nothing like knowing your foot is connected directly to the go-fast button!
Old November 10th 2010, 20:40
B-rock's Avatar
B-rock B-rock is offline
That's pretty trick. I don't think I've seen that outside of some of the super exotics. Does the Megasquirt system have to ability to measure intake air velocity and adjust the throttle bodies accordingly or does the DBW just replace the mechanical link?
Old November 10th 2010, 23:09
Luismj's Avatar
My setup is the same as yours! I like the go-fast cable, but i love this setup with more clean aircooled engine double throttle bodies!
(without turbo in this case...)
Old November 10th 2010, 23:15
Luismj's Avatar
Yes! The idea is to be controlled (adjust) by MegaSquirt! But if necessary it can work stand alone.
