Old January 1st 2003, 21:55
lightning bug's Avatar
What's the difference???
I need early 944 rear hubs and backing plates/caliper mounting brackets for my 993 conversion. Will late 85 work (85.5)? What's the difference between the early and late and why won't they work if so? THANKS!!!!!
Julian
'74 Super
Old January 6th 2003, 07:25
Jim Andritsakos's Avatar
No one ???
Well, you can use every year 944 NA & 924 TBO/GT rear caliper brackets and hubs are all the same.The differences you are refer to are for the later aluminium trailing arms who the caliper brackets cannot be removed (one piece casting)...
Rgds,
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
Old January 6th 2003, 12:47
Thanks!! The alum. are a wider track if I remember correctly, so I probably don't want them. Am I right?
Julian
'74 Super
Old January 6th 2003, 14:34
Pillow's Avatar
Pillow Pillow is offline
The only difference is the wider track... Up to you if that is what you want to do or not.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old January 6th 2003, 18:57
Pillow is correct.
1986 only 951 has are a bit wider (24mm) and 1987 and up are (64mm) maybe I don't remember the widths right at the moment but I can check this out if you like.
rgds
Jim Andritsakos
89 T3 Syncro panel
Old January 6th 2003, 19:54
Thanks fellas! I don't want any more track so I'll stick with the early set-up. Now where to find 'em.
Julian
'74 Super
