Old December 15th 2010, 18:33
-Alex- -Alex- is offline
944 turbo rear rotor dimensions <-86
Hello,
I am planning perhaps to make bells for rotors, and i need few dimensions for early 944 rear rotor, preferred 944 turbo rotor. I have -86 aluarms and brembos from that period 944, but no rotors.
Most of all i would like to know whats the circular dimension for handbrake shoes and the distance from bottom to rotor surface. Here in my picture they are 74 and 178mm
Old December 16th 2010, 08:23
Hi Alex,
The turbo came with two o/a depths of disc/drum 71mm and 100mm. To get a comparison with your 74mm dimension you will have to take off the thickness of the mounting face. The handbrake shoes are common across the 944 range so if your 178mm dimension is correct for one vehicle they should fit all models.
Old December 16th 2010, 11:18
No, i don't know the "178" dimension, thats my only problem Rest of i can measure and calculate from aluarm with caliper and hub. I just dont have any 944 rear rotor now. Yes, i found that 944 parking brake shoes fit also to many other porsche model.
According to this, they should fit 928, 993 etc.
http://www.9xx-parts.com/store/index...roduct_id=1481
Old December 16th 2010, 15:17
DORIGTT's Avatar
DORIGTT DORIGTT is offline
BMW E30 rear brake shoes are the same as the 944 from what I understand as well.
Old December 16th 2010, 16:51
I am not looking brake shoes Only looking the diameter from inside rotor parking brake shoes are.
Old December 26th 2010, 07:17
No one knows the inside diameter of rotor where parking brake shoes are? Or have rotor on the bench so could measure it?
Old December 26th 2010, 09:08
kombi211 kombi211 is offline
i just measured a set of rotors that I am getting to put on my square and they are right at 178mm inside DIA with 30mm contact area for the e brake shoes. but the rotor i have are off of a 996 vented and cross drilled not sure if that helps you
Old December 28th 2010, 11:50
1303C2/3 1303C2/3 is offline
They are 180mm inside diameter. The brake shoes are 25 mm in width. So 30 mm inside the drum should be ok. I m planning to use merc. W 211 T on 944 NA hubs. According to Brembo catalogue they have the same e brake dimensions. The merc disc is 300 mm dia and 22 mm thick.
