Old February 2nd 2011, 20:11
djmatio djmatio is offline
Beetle hard brake lines - stainless or regular?
Hi all,
I'm redoing all my brake lines and was wondering if stainless steel hard lines were any better or worse than the regular steel hard lines. Are looks the only plus? Are there any downsides or gotchas to stainless steel hard lines?
-Matt
DJMatio
1998 BMW 540i M-sport
1972 1302
Old February 4th 2011, 11:41
Yeah, its more expensive than Cunifer, which is dirt cheap and easy to work with
Old February 8th 2011, 09:07
Using stainless can be problematic as it work hardens quickly, its hard to bend and you will need a good quality flare to mate with other components. Its only advantage is the corrosion resistance.
On the other hand Kunifer (90%copper/10%nickel alloy) is reasonably mallable and is tolerant to poorly formed flares because it will mould (to a degree) to steel connectors etc. Its corrosion resistance is as good as if not better than SS in salt conditions.
SS brake lines, braided lines excepted is a bling thing not for serious performance.
Old February 8th 2011, 09:32
Clive, I quite like us both chasing each other around the forums and threads!
Old February 9th 2011, 09:31
Al,
Great minds...........................
