Old February 7th 2011, 09:58
Super duty tie rods and German tie rod ends
Super duty tie rods from Vdub engineering in Canada, painted and trial fitted but never used on the road. Standard width both short and long rods, come complete with lock nuts.
From the website:
Super Duty tie rods are manufactured from DOM tubing and feature a 60% thicker tube wall when compared to stock tie-rods. Standard (Bug) tie-rod ends can be used, and lock nuts are supplied with the kit. The outer (wheel) end has a knurled finish to provide a solid grip for easy adjusting. Flats are machined into the outer end to allow for a 19mm wrench, which avoids the use of pliers on the outside of the tie rod shaft when locking the jam nuts. The super duty's are designed for competition use.
Plus 4x tie rod ends (German)
Think one of the snap rings may be a different colour to the others, but exactly the same
Top quality bits for upgraded cars
I'm selling the lot for £80+post. Located in the UK
Please note these are stock pictures
Only getting rid of them because I'm going to persue my R&P installation - I'm going to replace the rods with a custom length set from Lanner @Vdub as soon as I'm ready.
